  • Bronze Donating Members
  • Member For: 13y 2m 4d
Hi All,
I have a space to bolt on the tow bar at the rear of my BA (tow bar is in the boot and came with the car when purchased) as per photo, however there is no fitting it appears for the electrical plug for the trailer lights. Does anyone know where is it or if there is a special fitting I need to buy or install?
post-50285-0-99118300-1331597747_thumb.j
  • Team Kickass
  • Member For: 21y 3m 17d
I think you need the tow pack for the plug etc.....
  • Member For: 18y 7m 17d
Think they all have the plug.. It in the boot on the rhs under carpet behind tail light..
My car doesnt have tow pack but spare plug there
  • Team Kickass
There is a spare connection there but it is nothing like a tow connection only has 2 pins.
Think I effed up.. Im talking about the plug in the loom not the plug for the trailer
  • Talks Cheap, Let's Race
  • Member For: 18y 6m
my turbo has the wiring for the trailer plug in the harness under the rh side tail light, you have to pull up the carpet and remove the liner on the side of the boot to get at it
  • 5 years later...
  • Cruise Whore
  • Moderating Team
  • Member For: 19y 9m 9d
Anyone know where I can buy a plug to suit this PWR 12V DC connector? Its in the boot loom RH side under the wall lining. Thanks.
  • Member For: 10y 3m 15d
  • Gender: Not Telling
I bought mine from eBay Gaz.
It was $70 delivered from a seller called adelaideparts.
Edit: It was a genuine bf sedan towbar wiring loom with reverse sensor and 12 pin plug.
I'm not sure if that's what you mean?
Edited by Puffwagon
  • Cruise Whore
  • Moderating Team
Thanks Puff.  I'm after the actual mating plug for the existing socket circled.  The 2 pins supply 12V DC (actually 11V measured) and I'm planning on hooking it up to a Cig Lighter socket so I can provide a Cig Lighter socket in the boot for things that need 12V DC power.  I found its always ON so I'll put a switch in-line as well.
Went to Ford, Repco, Jaycar and Altronics and none have the plug.  They all suggested I visit a wreckers and cut off the plug from a towbar loom that plugs into it.
