FAT-51X Member 254 Member For: 20y 11m 27d Gender: Male Location: Newcastle Posted 12/03/12 01:37 AM Share Posted 12/03/12 01:37 AM Hey guys..Relocated the battery to the opposite side fo the engine bay yesterday and as a result, have lost my A/C.. it wont cool at all.Has anyone come across this previously or have any idea as to why my A/C has shat itself??some background being we extended the battery leads and it wasnt a PW or plazmaman kit that was used.Any help would be greatly appreciated...Cheers,Troy Link to comment https://www.fordxr6turbo.com/forum/topic/79266-ac-not-working-after-battery-relocation/ Share on other sites More sharing options...
STAINLESS again plz You've changed man.... Donating Members 8,142 Member For: 14y 4m 8d Gender: Male Location: 2 Fuchsia Court, Narre Warren. 3805 Posted 12/03/12 02:10 AM Share Posted 12/03/12 02:10 AM terf the extentions and run it off starter motor, Link to comment https://www.fordxr6turbo.com/forum/topic/79266-ac-not-working-after-battery-relocation/#findComment-1208764 Share on other sites More sharing options...
unclewal Donating Members 583 Member For: 14y 7m 15d Posted 12/03/12 02:22 AM Share Posted 12/03/12 02:22 AM Wasnt there a reset procedure for the AC something to do with it going into. Start the car,With the car idleing set the AC to normal and let it sit still (do not rev the engine at all) for 2 mins, apparently this is the norm after a battery has been replace/disconnected. If the above doesnt work, disconnect the battery for 10 mins retry the procedure. Link to comment https://www.fordxr6turbo.com/forum/topic/79266-ac-not-working-after-battery-relocation/#findComment-1208778 Share on other sites More sharing options...
FAT-51X Member 254 Member For: 20y 11m 27d Gender: Male Location: Newcastle Posted 12/03/12 02:37 AM Author Share Posted 12/03/12 02:37 AM Going into????Excellent, ill give that a try.. thanks heaps.. what would u class as "Normal" for the a/c setting??? Link to comment https://www.fordxr6turbo.com/forum/topic/79266-ac-not-working-after-battery-relocation/#findComment-1208789 Share on other sites More sharing options...
TonezXR6T Italian Stig!! Donating Members 1,096 Member For: 14y 3m 8d Gender: Male Posted 12/03/12 02:55 AM Share Posted 12/03/12 02:55 AM OMG I got same problem man!! I moved my battery to the other side as well and ac does not work unless I turn the car off and turn back on get working again lolill try reset as well !!! Link to comment https://www.fordxr6turbo.com/forum/topic/79266-ac-not-working-after-battery-relocation/#findComment-1208804 Share on other sites More sharing options...
Rhino1980 09JET Member 1,510 Member For: 15y 10m 16d Gender: Male Location: E. Maitland Posted 12/03/12 05:22 AM Share Posted 12/03/12 05:22 AM Staino any idea why it does it man? Voltage or Amperage drop cant be that great just from a 2.5ft extension? Link to comment https://www.fordxr6turbo.com/forum/topic/79266-ac-not-working-after-battery-relocation/#findComment-1208860 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 6m 8d Gender: Male Location: Perth Posted 12/03/12 05:48 AM Share Posted 12/03/12 05:48 AM (edited) To come to think of it, a couple of times I have picked my car up from the tuners the air cond hasnt worked straight away. I know the battery would have gone flat. But after 10 - 15 mins of driving or restarting the car it was fine.It has nothing to do with volt drop Edited 12/03/12 05:49 AM by arronm Link to comment https://www.fordxr6turbo.com/forum/topic/79266-ac-not-working-after-battery-relocation/#findComment-1208870 Share on other sites More sharing options...
TonezXR6T Italian Stig!! Donating Members 1,096 Member For: 14y 3m 8d Gender: Male Posted 12/03/12 05:58 AM Share Posted 12/03/12 05:58 AM On 12/03/2012 at 5:48 AM, arronm said: To come to think of it, a couple of times I have picked my car up from the tuners the air cond hasnt worked straight away. I know the battery would have gone flat. But after 10 - 15 mins of driving or restarting the car it was fine.It has nothing to do with volt dropso can we fix this problem ?used by Garret Link to comment https://www.fordxr6turbo.com/forum/topic/79266-ac-not-working-after-battery-relocation/#findComment-1208872 Share on other sites More sharing options...
1600dave Donating Members 872 Member For: 14y 3m 26d Posted 12/03/12 06:21 AM Share Posted 12/03/12 06:21 AM Mine did it the other week when I'd been messing around, I checked fuses and unplugged the AC compressor just checking connections, on the side of the road as it was a stinking hot day. Just doing that fixed it, hasn't played up since. Link to comment https://www.fordxr6turbo.com/forum/topic/79266-ac-not-working-after-battery-relocation/#findComment-1208876 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 5m 11d Gender: Male Location: Probably above atmospheric pressure Posted 12/03/12 06:47 AM Share Posted 12/03/12 06:47 AM I found my AC not working after my tune, while on a long drive north, had been trying to run it for an hour. Called up XFT and was advised to turn car off, on, start AC and sit still until it kicks in after a minute or two. Has been fine after that, including battery disconnects. Link to comment https://www.fordxr6turbo.com/forum/topic/79266-ac-not-working-after-battery-relocation/#findComment-1208889 Share on other sites More sharing options...
