TheOne Member 80 Member For: 13y 4m 22d Gender: Male Posted 11/03/12 03:30 AM Share Posted 11/03/12 03:30 AM G'day guys,I'm a recent convert to Fords, have to say I'm loving my 2003 BA XR6 Turbo to death, it's an awesome car, but I seem to be having an issue lately - it seems that at 140kms p/h the power stalls (feels like when you have the traction control on). As soon as it gets to 140kms it spits and loses all its grunt...it's only recently been doing this (last 2 weeks or so), sometimes it does it and sometimes it doesn't. The only modifications I have are a straight through cat, centre muffler removed and K&N air filter. It already had these and was running fine, so I'm wondering if it is a fuel issue? Or whether it could be boost spiking (although I would think that if this was the issue it would be doing it throughout the rev range regardless of speed). It only ever does it at 140kms. Does anybody have an clue as to what the issue may be?Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/79258-power-lost-at-100kms/ Share on other sites More sharing options...
gsd112 Donating Members 604 Member For: 14y 8m 6d Gender: Male Location: Penrith Posted 11/03/12 03:45 AM Share Posted 11/03/12 03:45 AM If you havent got a custom tune with the cat guttered I would do so ASAP. And dont go boosting it until you do or you might find a hole in the side of your block like a guy I know and his seemed fine for a few weeks as well until bang. Link to comment https://www.fordxr6turbo.com/forum/topic/79258-power-lost-at-100kms/#findComment-1208416 Share on other sites More sharing options...
TheOne Member 80 Member For: 13y 4m 22d Gender: Male Posted 11/03/12 04:22 AM Author Share Posted 11/03/12 04:22 AM Thanks gsd112,I've been wanting to get the Xcal 3 tuner, so this might be a good time to do it. Do you think it's strange that it only happens at 140kms or when it changes into 3rd gear? Appreciate the advice!Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/79258-power-lost-at-100kms/#findComment-1208425 Share on other sites More sharing options...
TheOne Member 80 Member For: 13y 4m 22d Gender: Male Posted 11/03/12 04:23 AM Author Share Posted 11/03/12 04:23 AM On 11/03/2012 at 3:45 AM, gsd112 said: If you havent got a custom tune with the cat guttered I would do so ASAP. And dont go boosting it until you do or you might find a hole in the side of your block like a guy I know and his seemed fine for a few weeks as well until bang.Thanks gsd112,I've been wanting to get the Xcal 3 tuner, so this might be a good time to do it. Do you think it's strange that it only happens at 140kms or when it changes into 3rd gear? Appreciate the advice!Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/79258-power-lost-at-100kms/#findComment-1208428 Share on other sites More sharing options...
gsd112 Donating Members 604 Member For: 14y 8m 6d Gender: Male Location: Penrith Posted 11/03/12 04:31 AM Share Posted 11/03/12 04:31 AM No idea, but I know his car was leaning out due to the cat being guttered and kaboom, rod out the side of the block. He didnt relise it was running so lean but his would go into limp mode occasionally with over boost. Link to comment https://www.fordxr6turbo.com/forum/topic/79258-power-lost-at-100kms/#findComment-1208432 Share on other sites More sharing options...
KeddyXR6T Donating Members 320 Member For: 16y 2m 4d Gender: Male Location: Melbourne Posted 12/03/12 09:55 PM Share Posted 12/03/12 09:55 PM I Had the same drama its the valve springs retarding not good best bet is some injectors do the valve springs and just get a flash and dash done by someone if your planning on a XCAL 3 also do yourself a favor and put a earls turbo oil feed line on it too before the turbo go's BANG TING TING TING Link to comment https://www.fordxr6turbo.com/forum/topic/79258-power-lost-at-100kms/#findComment-1209174 Share on other sites More sharing options...
TheOne Member 80 Member For: 13y 4m 22d Gender: Male Posted 13/03/12 08:40 PM Author Share Posted 13/03/12 08:40 PM I Had the same drama its the valve springs retarding not good best bet is some injectors do the valve springs and just get a flash and dash done by someone if your planning on a XCAL 3 also do yourself a favor and put a earls turbo oil feed line on it too before the turbo go's BANG TING TING TINGThanks for the advice mate. I know the valve springs are very temperamental in the BAs, I just read a similar thread to what mine's doing and it seems like it could be the coil packs. Only because my car had these modifications on it before and the car was running fine, it's only recently started playing up. I still think I'll get the Xcal, my car already has the Earl's turbo oil feed on it! The first owner must have learnt this lesson because I think the turbo has been replaced on it at some stage, the coil packs have never been replaced though and it's done 160,000kms. Also, do you know what colour the standard injectors are on a XR6T?Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/79258-power-lost-at-100kms/#findComment-1209626 Share on other sites More sharing options...
MY ROD GOT OUT Member 434 Member For: 14y 8m 7d Posted 13/03/12 09:05 PM Share Posted 13/03/12 09:05 PM Standard injectors are blue mate Link to comment https://www.fordxr6turbo.com/forum/topic/79258-power-lost-at-100kms/#findComment-1209628 Share on other sites More sharing options...
TheOne Member 80 Member For: 13y 4m 22d Gender: Male Posted 14/03/12 01:52 AM Author Share Posted 14/03/12 01:52 AM Thanks m8Thought l mite have had some phoon ones on it guess not. cheers. Link to comment https://www.fordxr6turbo.com/forum/topic/79258-power-lost-at-100kms/#findComment-1209704 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 11m 14d Gender: Male Location: @ my laptop Posted 14/03/12 02:55 AM Share Posted 14/03/12 02:55 AM there the same injectors, also same as NA 6 and the 3 different V8's in the BA and BF range Link to comment https://www.fordxr6turbo.com/forum/topic/79258-power-lost-at-100kms/#findComment-1209717 Share on other sites More sharing options...
