KeddyXR6T Donating Members 320 Member For: 15y 10m 11d Gender: Male Location: Melbourne Posted 11/03/12 12:19 PM Author Share Posted 11/03/12 12:19 PM I took it for tune after losing a fair bit of power and oil passing thru the tube that gose between the rocket cover and intake mainfold I think its called the pcm valve I was told im losing boost through the pistons I need a rebuild demostrated to me by when boosting on the dyno the oil dipstick lifted Link to comment Share on other sites More sharing options...
Pazzo Donating Members 11,132 Member For: 14y 2m 26d Gender: Male Posted 11/03/12 06:44 PM Share Posted 11/03/12 06:44 PM Before you do anything, same thing was happening to Foon in S.A, changed his PCM hose and all fixed. Do that before ripping your engine apart. Link to comment Share on other sites More sharing options...
Pazzo Donating Members 11,132 Member For: 14y 2m 26d Gender: Male Posted 11/03/12 07:42 PM Share Posted 11/03/12 07:42 PM Sorry called PCV hose not a PCM hose. My bad. Link to comment Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 1m 26d Gender: Male Location: SE Melbourne Posted 11/03/12 07:49 PM Share Posted 11/03/12 07:49 PM I took it for tune after losing a fair bit of power and oil passing thru the tube that gose between the rocket cover and intake mainfold I think its called the pcm valve I was told im losing boost through the pistons I need a rebuild demostrated to me by when boosting on the dyno the oil dipstick liftedPcv valve and hose is found on the rocker cover right near the firewall. The one you see at the front going to the intake is just a breather. Link to comment Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 21y 8m 23d Gender: Male Location: Victoria Posted 11/03/12 09:31 PM Share Posted 11/03/12 09:31 PM In either case if that's blocked up the dipstick will pop out. Link to comment Share on other sites More sharing options...
KeddyXR6T Donating Members 320 Member For: 15y 10m 11d Gender: Male Location: Melbourne Posted 11/03/12 11:30 PM Author Share Posted 11/03/12 11:30 PM hmm yes I think I will replace the PCV valve first any ideas on the missing power Link to comment Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 1m 26d Gender: Male Location: SE Melbourne Posted 12/03/12 12:34 AM Share Posted 12/03/12 12:34 AM Does the car run rough or just down on power? Have you thought about the valve springs?Otherwise a rod my be bent (usually hear a tapping sound) or your piston rings gone. Maybe get a compression and leak down test done before pulling your motor out.First thing get the pcv valve checked or replaced, they are cheap. Link to comment Share on other sites More sharing options...
KeddyXR6T Donating Members 320 Member For: 15y 10m 11d Gender: Male Location: Melbourne Posted 12/03/12 12:50 AM Author Share Posted 12/03/12 12:50 AM Done the vavle springs had to for the 4spd to get it over 240kw pretty sure the rings have had there turn its down pedal round the 6grand mark she starts carring onAgain Thanks All You Boys For the Suggestions Watch This Space As I Will Do The PCV Valve And Let Yous Know If It Solves The Problem Link to comment Share on other sites More sharing options...
KeddyXR6T Donating Members 320 Member For: 15y 10m 11d Gender: Male Location: Melbourne Posted 13/03/12 04:19 PM Author Share Posted 13/03/12 04:19 PM So I went and seen Adam down at FTG wreckers (great place helpful dude) grabbed a PCV valve and a new breather tube cause the bend that fits to the rocker cover is worn I'll be flat out the rest of this week and weekend with the grand prix in town but the second I fit it I will let you all know if it solves the problem or if I'm off to do the dreaded compression test so wish me luck and thanks again guys Link to comment Share on other sites More sharing options...
MX Dave Donating Members 545 Member For: 13y 9m 12d Gender: Male Posted 13/03/12 11:05 PM Share Posted 13/03/12 11:05 PM Make sure you use a teaspoon of oil on your second compression test to allocate where the problem lies! Link to comment Share on other sites More sharing options...
