Maintenance Questions
patrick1234
  • Member For: 13y 11d
Hello im new here as I just got a xr6 turbo ute, everything is sweet with it but im keen on doing this boost solenoid thing, but the pictures dont work, if someone could get me a photo of the boost solenoid it would be much appreciated. Cheers pat
  • Member For: 21y 6d
hi mate, sorry for the broken pictures, they are all working now. needed to upgrade the server.
Enjoy the new found power after the mod.
  • 4 weeks later...
Hello Patrick here, I've got a few questions about some maintenance I'm going to do on my 2006 xr6 turbo ute
They are :
1.cleaning throttle body
2.boost leak test
3. o2 sensor
1. Just wanted to know what throttle body cleaner you guys recommend and if you have to take off the ford inter cooler pipes to get into the body
2. Boost leak test, have you guys made one before or did you buy it? and was it relatively easy
3. o2 Sensor, which one did you guys get, eg best brand type? Is there two sensors I can see one but heard there is two. Reason being my fuel consumption is dismal
Any help would be great, thanks Pat.
  • Member For: 17y 2m 27d
1- Wynns throttle body and carby cleaner, take off whatever you have to to get at the throttle. Depends what you've changed under the bonnet, see that sticky mentioned above. On mine I have to remove pipes from turbo and cooler to the crossover on top, then take crossover off (mind the BOV).
3)-I replaced the engine bay O2 sensor with a bosch one from ebay, cost bugger all, $66 posted. Bought it from seller automotiveheaven03
There is another one further down the exhaust (is this BFs only?) but I am tuned and I'm told they turn it off during tuning to avoid it throwing error codes.
  • Member For: 13y 19d
nice info guys will be doing the above also.
after cleaning throttle body has anyones car run smoother etc?
has anyone noticed a better result after buying a new O2 sensor?
cheers
Edited by NRGIZE
Hey thanks for the replies, il check out that thread on the tb thanks, My car came with a tune when I bought it but I dont know any more than that and yeah it is just a bf, il try one of the bosch ones so thanks for that, yeah also il have to take off my cross over off to get to it.
Thanks
I had improved idle after changing o2 sensor. Mine is possibly valve spring related as well though, bad idle (BAD...like a massive cam) after giving it a bit of herbs, but only happens one in a hundred mashes of throttle.
Throttle body I've always done with boost solenoid lubing so can't comment on it alone.
