esss15 Member 35 Member For: 16y 2m 8d Posted 06/03/12 08:16 AM Share Posted 06/03/12 08:16 AM 2010 F6 ute car was stock til bout 5000ks. I fitted PWintercooler kit, PW intake, injectors, 4inch into 3.5inch exhaust, Hi torquemodded the flapper on the turbo. Hi torque tuned it and it made 356rwkw at 15-16psi. It has run this tune only until now at 13000k's.Not thrashed, maybe once a day at most I give one quick second gear pull on th eway home from work. I recently had pipes off the car and thought I would re check the turbo compressor to housing clearance by feel only. As did thischeck when I fitted the mods to the car. What I saw pooled at the bottom of the compressor housing got me worried.. Pool of oil..!The clearance was at least three times what it was at 5000k's!Doesn't look good,About to head back to hitorque and see what they think when I get time.Just thinking if it is dusted what is a good replacement turbo for these and how much..? Or is it better getting it repaired?Could be persuaded to go slightly bigger for a bit more HP..Any info would be great guy'sSam Link to comment https://www.fordxr6turbo.com/forum/topic/79208-turbo-on-my-fg-f6-is-on-the-way-out-after-13000ks/ Share on other sites More sharing options...
mad_rx2 Banned 148 Member For: 16y 1m 22d Gender: Male Location: Glen Waverley Posted 06/03/12 08:22 AM Share Posted 06/03/12 08:22 AM When I replaced my intercooler on my stock (at the time) xr50 when it had 20,000kms I noticed there was heaps of oil in the crossover intake pipe and in the mouth of the turbo, I presumed it would be from the engine breather.I didn't really think it was anything to worry about, I have since upgraded the turbo. I know Dragons lair motorsports makes some sweet direct swap turbo's including wastegate etc.Let us know how you go 1 Link to comment https://www.fordxr6turbo.com/forum/topic/79208-turbo-on-my-fg-f6-is-on-the-way-out-after-13000ks/#findComment-1206567 Share on other sites More sharing options...
Henz Tampon inserted, Auto Acquired, next purchase a new handbag Donating Members 9,946 Member For: 17y 1m 23d Gender: Male Location: Vic Posted 06/03/12 08:25 AM Share Posted 06/03/12 08:25 AM A pool of oil is normal mate. I wouldn't be to stressed yet. But a bigger front wheel and comp cover would be fine. Link to comment https://www.fordxr6turbo.com/forum/topic/79208-turbo-on-my-fg-f6-is-on-the-way-out-after-13000ks/#findComment-1206570 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 6m 16d Gender: Male Location: Perth Posted 06/03/12 08:36 AM Share Posted 06/03/12 08:36 AM Its probably fine, but best tell the missus its rooted and get a bigger one. 6 Link to comment https://www.fordxr6turbo.com/forum/topic/79208-turbo-on-my-fg-f6-is-on-the-way-out-after-13000ks/#findComment-1206577 Share on other sites More sharing options...
Kirty23 Member 6 Member For: 12y 11m 16d Posted 26/05/12 02:03 PM Share Posted 26/05/12 02:03 PM Fg turbos had manufacturing fault... Mate flogged his shaft and bearing and was told it was manufacture fault. Was heavily mod'd so wouldn't be able to claim. Ended up buying aftermarket turbo with bigger waste gate/exhaust manifold ended up getting more boost at lower psi Link to comment https://www.fordxr6turbo.com/forum/topic/79208-turbo-on-my-fg-f6-is-on-the-way-out-after-13000ks/#findComment-1243829 Share on other sites More sharing options...
bradles024 Donating Members 1,145 Member For: 15y 5m 29d Gender: Male Posted 26/05/12 03:40 PM Share Posted 26/05/12 03:40 PM More boost at lower psi? 6 Link to comment https://www.fordxr6turbo.com/forum/topic/79208-turbo-on-my-fg-f6-is-on-the-way-out-after-13000ks/#findComment-1243846 Share on other sites More sharing options...
sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 15y 6m 17d Gender: Male Location: Far north queensland Posted 26/05/12 07:24 PM Share Posted 26/05/12 07:24 PM it's basic physics bradles, bigger turbos are more thermally efficient Link to comment https://www.fordxr6turbo.com/forum/topic/79208-turbo-on-my-fg-f6-is-on-the-way-out-after-13000ks/#findComment-1243856 Share on other sites More sharing options...
MiKa Donating Members 4,243 Member For: 18y 8m 22d Gender: Male Location: Melbourne, VIC Posted 26/05/12 09:05 PM Share Posted 26/05/12 09:05 PM (edited) Picture a fan blowing air.. a big fan on low can blow as much or more air as a little fan on med/high.. So big fan doesn't work as hard to do the same job.. Paint that fan black and take it to SA and you have a winner... Edited 26/05/12 09:06 PM by MiKa 5 Link to comment https://www.fordxr6turbo.com/forum/topic/79208-turbo-on-my-fg-f6-is-on-the-way-out-after-13000ks/#findComment-1243863 Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 5m 21d Gender: Male Location: SE Melbourne Posted 26/05/12 10:17 PM Share Posted 26/05/12 10:17 PM (edited) Picture a small BBQ and a big BBQ. The small one will heat up a lot quicker than the big one but not hold near as much meat. The big one will take ages to heat up but once it does it's going to cook the shhhiiit out of the meat. Now turn the gas down on the big BBQ cause you don't need it on full, it will burn your food. With less gas you can cook a lot more meat with the big BBQ but heating it up constantly will be less efficient than the small BBQ. Meat = volume of air (as referred to as boost)Heat = PSI (the pressure of the air)Burnt meat = overboost Edited 26/05/12 10:25 PM by Paulie2256 3 Link to comment https://www.fordxr6turbo.com/forum/topic/79208-turbo-on-my-fg-f6-is-on-the-way-out-after-13000ks/#findComment-1243872 Share on other sites More sharing options...
freeze_dk I am dissatisfied with my current employment situation Donating Members 8,610 Member For: 18y 7m 15d Gender: Male Posted 27/05/12 12:48 AM Share Posted 27/05/12 12:48 AM Now I feel like bbq 1 Link to comment https://www.fordxr6turbo.com/forum/topic/79208-turbo-on-my-fg-f6-is-on-the-way-out-after-13000ks/#findComment-1243932 Share on other sites More sharing options...
