21220 Silver Donating Members 27 Member For: 16y 2m 19d Gender: Male Location: Canberra Posted 02/03/12 12:32 PM Share Posted 02/03/12 12:32 PM Still learning so please don't flame lol. Why would you use a engine oil cooler? Is it do with power levels or driving conditions? I would have thought that changing your thermostat would sort out temp issues.Honest question just trying to understand why people fit them? Link to comment https://www.fordxr6turbo.com/forum/topic/79168-engine-oil-coolers/ Share on other sites More sharing options...
Benny Member 1,869 Member For: 21y 10m 21d Gender: Male Location: Newcastle Posted 02/03/12 09:16 PM Share Posted 02/03/12 09:16 PM In most processes heat is an undesireable condition, which reduces the life of equipment. This goes the same for your engine. Your oil is designed to function efficiently during normal operation but when you push your engine to it's maximum the oil thins and provides less protection. So installing a cooler will allow the oil to cool and remain closer to it's designed temperature range of operation. This will improve reliability and prolong engine life by reducing wear to bearings etc.Benny. Link to comment https://www.fordxr6turbo.com/forum/topic/79168-engine-oil-coolers/#findComment-1204884 Share on other sites More sharing options...
riptide Member 733 Member For: 14y 5m 9d Gender: Male Location: Auckland, New Zealand Posted 02/03/12 09:28 PM Share Posted 02/03/12 09:28 PM I think what 21220 was asking is why do you need two forms of cooling. If the radiator is doing it's job should you really need an extra cooler targeting the oil? Does the oil heat faster than the block?I always wondered this too. Link to comment https://www.fordxr6turbo.com/forum/topic/79168-engine-oil-coolers/#findComment-1204885 Share on other sites More sharing options...
Benny Member 1,869 Member For: 21y 10m 21d Gender: Male Location: Newcastle Posted 02/03/12 09:53 PM Share Posted 02/03/12 09:53 PM The oil and coolant are two seperate systems that do two different things in the engine. The oil is for lubricating bearings etc and the water is to cool the block and head. Lowering your thermostat would lower the operating temperature of the engine but cooling the oil wont have much effect on reducing engines temps but allow the oil to remian in it's ideal temp range during spirited use which will provide better protection.Lowering either of these systems too far can affect the correct operation of your engine so care must be taken.Benny. Link to comment https://www.fordxr6turbo.com/forum/topic/79168-engine-oil-coolers/#findComment-1204894 Share on other sites More sharing options...
RegSpec Cruise Control 1,417 Member For: 18y 5m 30d Gender: Male Location: Macksville NSW. Posted 02/03/12 11:44 PM Share Posted 02/03/12 11:44 PM (edited) Another thing to consider is a stock XR6T/Typhoon does not have a very large oil pan.....and as the oil flows through a red hot turbo it gets heated up...fast...If the oil overheats the car goes into limp mode.....so to fix this I fitted an oil cooler....Mounted it under the drivers side headlight and ran a couple of 16mmID. hoses from the filter across the front to the cooler.....this not only gives me the advantage of cooler oil....but also increases the capacity of the oil system by more than a litre.....If you cut some slots in the splashshield in front of the front wheel (as per the pic) you'll get a suction effect as the front wheel spins to draw air through the cooler without having to stuff around with ducting air to the cooler.Hints.....Always use good quality "high-temperature" hose with compatible fittings and use proper clamps along its route to avoid abrasion of the hoses. Edited 02/03/12 11:48 PM by BionicXR6T 1 Link to comment https://www.fordxr6turbo.com/forum/topic/79168-engine-oil-coolers/#findComment-1204918 Share on other sites More sharing options...
1600dave Donating Members 872 Member For: 14y 5m 17d Posted 03/03/12 03:20 AM Share Posted 03/03/12 03:20 AM Good oil cooler setups run a thermostat too, B&M make them, as oil takes a while to warm up so if its being driven on the street it'd struggle to get up to temp. Link to comment https://www.fordxr6turbo.com/forum/topic/79168-engine-oil-coolers/#findComment-1205000 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 8m Gender: Male Location: Perth Posted 03/03/12 03:29 AM Share Posted 03/03/12 03:29 AM A fitted cooler to BA BFhttp://www.fordxr6turbo.com/forum/topic/79178-ba-bf-engine-oil-cooler/page__fromsearch__1 Link to comment https://www.fordxr6turbo.com/forum/topic/79168-engine-oil-coolers/#findComment-1205008 Share on other sites More sharing options...
nelsonian101 Donating Members 961 Member For: 17y 2d Gender: Male Location: Sydney Posted 09/03/12 09:21 PM Share Posted 09/03/12 09:21 PM On 02/03/2012 at 11:44 PM, BionicXR6T said: Another thing to consider is a stock XR6T/Typhoon does not have a very large oil pan.....and as the oil flows through a red hot turbo it gets heated up...fast...If the oil overheats the car goes into limp mode.....so to fix this I fitted an oil cooler....Mounted it under the drivers side headlight and ran a couple of 16mmID. hoses from the filter across the front to the cooler.....this not only gives me the advantage of cooler oil....but also increases the capacity of the oil system by more than a litre.....If you cut some slots in the splashshield in front of the front wheel (as per the pic) you'll get a suction effect as the front wheel spins to draw air through the cooler without having to stuff around with ducting air to the cooler.Hints.....Always use good quality "high-temperature" hose with compatible fittings and use proper clamps along its route to avoid abrasion of the hoses.I like this idea for cooling re the vents but does it suck a lot of water in too? Link to comment https://www.fordxr6turbo.com/forum/topic/79168-engine-oil-coolers/#findComment-1208104 Share on other sites More sharing options...
MX Dave Donating Members 545 Member For: 14y 2m 22d Gender: Male Posted 09/03/12 09:32 PM Share Posted 09/03/12 09:32 PM (edited) Oil coolers are a sealed unit. Water on it would only aid in the cooling. Edited 09/03/12 09:33 PM by MX Dave Link to comment https://www.fordxr6turbo.com/forum/topic/79168-engine-oil-coolers/#findComment-1208106 Share on other sites More sharing options...
