solly007 Member 40 Member For: 16y 2d Posted 28/02/12 08:05 AM Share Posted 28/02/12 08:05 AM Trying to fit up a eboost controller and having trouble trying to get a RPM signal to tap into.Ford runs a can bus signal and the eboost needs a signal between 3.5 and running voltage. I have hurd ther is a connector that you can connect into for taxis and artermarket cruise control. Any help pls. Link to comment https://www.fordxr6turbo.com/forum/topic/79116-anyone-fitted-a-eboost1-controllerhelp/ Share on other sites More sharing options...
rbjet Skid Machine Donating Members 1,640 Member For: 13y 10m 19d Gender: Male Posted 28/02/12 08:51 PM Share Posted 28/02/12 08:51 PM Why exactly did you want to connect the eboost?You don't need it to control boost on a falcon. Link to comment https://www.fordxr6turbo.com/forum/topic/79116-anyone-fitted-a-eboost1-controllerhelp/#findComment-1203532 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 6m 20d Gender: Male Location: Perth Posted 29/02/12 12:01 AM Share Posted 29/02/12 12:01 AM You need an MSD/FRP Tach driver. It will convert the crank angle sensor output to a 5v square wave signal that the eboost can use. Link to comment https://www.fordxr6turbo.com/forum/topic/79116-anyone-fitted-a-eboost1-controllerhelp/#findComment-1203604 Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 4m 21d Gender: Male Location: SE Melbourne Posted 29/02/12 02:17 AM Share Posted 29/02/12 02:17 AM On 28/02/2012 at 8:51 PM, rbjet said: Why exactly did you want to connect the eboost?You don't need it to control boost on a falcon.I'm assuming the op is trying to set different boost levels at different revvs. Good way to help with traction off the line. Link to comment https://www.fordxr6turbo.com/forum/topic/79116-anyone-fitted-a-eboost1-controllerhelp/#findComment-1203686 Share on other sites More sharing options...
rbjet Skid Machine Donating Members 1,640 Member For: 13y 10m 19d Gender: Male Posted 29/02/12 02:21 AM Share Posted 29/02/12 02:21 AM Oh yep, wasn't too sure if you could do that in these cars. Link to comment https://www.fordxr6turbo.com/forum/topic/79116-anyone-fitted-a-eboost1-controllerhelp/#findComment-1203689 Share on other sites More sharing options...
RAP1D Member Donating Members 3,739 Member For: 18y 10m 23d Gender: Male Location: Sydney NSW Posted 29/02/12 04:24 AM Share Posted 29/02/12 04:24 AM Yep, I run a Greddy Profec in my G6, its nice to have a lower boost setting for low gears and traction Link to comment https://www.fordxr6turbo.com/forum/topic/79116-anyone-fitted-a-eboost1-controllerhelp/#findComment-1203734 Share on other sites More sharing options...
