Ganador Member 5 Member For: 13y 3m 18d Posted 27/02/12 11:34 AM Share Posted 27/02/12 11:34 AM Hey guys, First post.My BF MKll manual has started to have a 5700 limiter in every gear. Its lightly modified with custom tunes but the limiter used to be about 6400 or there abouts.Wondering if yous would know what would be causing this?Cheers, Dave Link to comment https://www.fordxr6turbo.com/forum/topic/79104-5700-limiter-every-gear/ Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 8m 22d Gender: Male Location: Perth Posted 27/02/12 11:40 AM Share Posted 27/02/12 11:40 AM Has it seen a set of plugs in recent memory? Link to comment https://www.fordxr6turbo.com/forum/topic/79104-5700-limiter-every-gear/#findComment-1202720 Share on other sites More sharing options...
Ganador Member 5 Member For: 13y 3m 18d Posted 27/02/12 11:44 AM Author Share Posted 27/02/12 11:44 AM Yeh, new set about 6000km ago. Link to comment https://www.fordxr6turbo.com/forum/topic/79104-5700-limiter-every-gear/#findComment-1202722 Share on other sites More sharing options...
JVK Silver Donating Members 751 Member For: 19y 5m 27d Gender: Male Location: North West Hot Hell,VIC Posted 27/02/12 08:06 PM Share Posted 27/02/12 08:06 PM Were they gapped to suit hi boost? Link to comment https://www.fordxr6turbo.com/forum/topic/79104-5700-limiter-every-gear/#findComment-1202838 Share on other sites More sharing options...
sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 15y 7m 19d Gender: Male Location: Far north queensland Posted 27/02/12 08:31 PM Share Posted 27/02/12 08:31 PM what diff do you have in it?maybe the tuner dropped your rev limit Link to comment https://www.fordxr6turbo.com/forum/topic/79104-5700-limiter-every-gear/#findComment-1202843 Share on other sites More sharing options...
Ganador Member 5 Member For: 13y 3m 18d Posted 27/02/12 10:26 PM Author Share Posted 27/02/12 10:26 PM Plugs are gapped the same as the old ones.Tune was done a while ago. Nothings changed since then. It's only just recently been doing this. Link to comment https://www.fordxr6turbo.com/forum/topic/79104-5700-limiter-every-gear/#findComment-1202876 Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 6m 23d Gender: Male Location: SE Melbourne Posted 27/02/12 10:34 PM Share Posted 27/02/12 10:34 PM (edited) First check for codes. If there aren't any, try reflashing your pcm with the same tune. then see if the limit is still there. Edited 27/02/12 10:34 PM by Paulie2256 Link to comment https://www.fordxr6turbo.com/forum/topic/79104-5700-limiter-every-gear/#findComment-1202881 Share on other sites More sharing options...
Ganador Member 5 Member For: 13y 3m 18d Posted 27/02/12 11:59 PM Author Share Posted 27/02/12 11:59 PM Did all that on Sunday. Is there a clutch switch (possibly broken) that limits the rev when pressed? Link to comment https://www.fordxr6turbo.com/forum/topic/79104-5700-limiter-every-gear/#findComment-1202926 Share on other sites More sharing options...
Brods Member 433 Member For: 14y 10m 16d Gender: Male Posted 28/02/12 01:14 AM Share Posted 28/02/12 01:14 AM I wouldn't be revving past 5.5 if I hadn't done oil pump gears IMO Link to comment https://www.fordxr6turbo.com/forum/topic/79104-5700-limiter-every-gear/#findComment-1202955 Share on other sites More sharing options...
1600dave Donating Members 872 Member For: 14y 5m 4d Posted 28/02/12 04:06 AM Share Posted 28/02/12 04:06 AM Lowering the rev limit won't help oil pump gears much, just make it easier to hit limiter which is what they don't like.When does the car make peak power? Do you need all 6400rpm? Link to comment https://www.fordxr6turbo.com/forum/topic/79104-5700-limiter-every-gear/#findComment-1203004 Share on other sites More sharing options...
