  • Member For: 13y 1m 17d
I've just replaced my turbo engine in my ba with a n/a bf engine and box . Put the red top on and runs awesome on standard boost with a ss cold induction kit. Old motor went into self distruct after waste gate actuator stopped working. This is the ghost misfire at 3500-4000 rpm over boost will destroy yr motor always sooner rather than later. So have a ba turbo head in good nicker and other bits off the block will trade for decent blow off valve to suit
  • Replies 23
  • Member For: 22y 4m 23d
Well good luck to you if n/a engine is used in Turbo application. The differences in piston crown and gudgeon pin will make this a short lived experience if you are not EXTREMELY careful and lucky, as compression ration is waaaaay too high for a turbo application, and self detonation and pinging can destroy your engine really easily.
  On 01/03/2012 at 7:27 AM, 1600dave said:
N/A heads are the same aren't they, except for exhaust valves and valve springs? Could be another option...
Yes the heads are the same, except for the differences you mention. Be aware though, the to replace the exhaust valves with Turbo ones, will set you back about $100 each (12 of them in the head) so you do the maths....
  • Member For: 13y 9m 10d
okay update with how im tracking... car went in and took 3-4 weeks for them to get back to me.. as I knew the engine was down the sh*tter, the heads not to much damage and can be fixed the oil pump is still good and obviously the sump is rooted... later that day called atomic.. $7,900 for the 698 Short + $150 for a new sump + $336 for delivery to Townsville.. havent put the order in yet but will probably be going ahead with it on Monday... thoughts? good points the internals was only thing holding me back from 500+rwkw so will hopefully see that mark with the 698 short...
