Peever Donating Members 23 Member For: 13y 9m 11d Gender: Male Location: Townsville, North QLD Posted 27/02/12 08:38 AM Share Posted 27/02/12 08:38 AM I blew the engine in my Falcon it turned out to be bad fuel that blew it... (not happy) anyways I was running 410rwkw through a BF mkII which Iv been told isnt to much drama... anyways when I blew it as you can imagine made a big mess of th e block and the sump.. now Im looking at a new block and I know my next question is gonna sound super stupid.. but I dont want to ask these questions at a mechanic cause they will probaly take advantage of it and charge me a sh*t tin... the engine I have found is a BF mkII block it has had the sump weilded professionally as it had a crack.. will this cause dramas down the road? also it doesnt come with Manifold Wiring, oil pump and accessories.. I dont think I need any of those things anyway right? and If I do what is needed? any help on this is muchly appreciated...thanks in advance,Peever. Link to comment https://www.fordxr6turbo.com/forum/topic/79097-help-about-engine-replacement/ Share on other sites More sharing options...
Peever Donating Members 23 Member For: 13y 9m 11d Gender: Male Location: Townsville, North QLD Posted 28/02/12 05:49 AM Author Share Posted 28/02/12 05:49 AM anyone please?? =( Link to comment https://www.fordxr6turbo.com/forum/topic/79097-help-about-engine-replacement/#findComment-1203084 Share on other sites More sharing options...
Pazzo Donating Members 11,132 Member For: 14y 6m 26d Gender: Male Posted 28/02/12 05:55 AM Share Posted 28/02/12 05:55 AM Is that the one on ebay? if so just buy a new sump if your worried, oil pump you should replace anyway with a Atomic one for safety. Wiring cannot help there. Link to comment https://www.fordxr6turbo.com/forum/topic/79097-help-about-engine-replacement/#findComment-1203090 Share on other sites More sharing options...
Peever Donating Members 23 Member For: 13y 9m 11d Gender: Male Location: Townsville, North QLD Posted 28/02/12 05:57 AM Author Share Posted 28/02/12 05:57 AM yes its the one on ebay.. =) It looks like a pretty good buy... thanks for the help.. can anyone shed some light on the manifold wiring? If Im correct that shouldnt be an issue?? Link to comment https://www.fordxr6turbo.com/forum/topic/79097-help-about-engine-replacement/#findComment-1203094 Share on other sites More sharing options...
Pazzo Donating Members 11,132 Member For: 14y 6m 26d Gender: Male Posted 28/02/12 05:59 AM Share Posted 28/02/12 05:59 AM use the one on your car? should work. Link to comment https://www.fordxr6turbo.com/forum/topic/79097-help-about-engine-replacement/#findComment-1203099 Share on other sites More sharing options...
Peever Donating Members 23 Member For: 13y 9m 11d Gender: Male Location: Townsville, North QLD Posted 28/02/12 06:39 AM Author Share Posted 28/02/12 06:39 AM sweet as.. im not very mechanical minded hence why I wanted to make sure... think Imma go for this one on ebay.. been looking for a few months and not much has come up.. Link to comment https://www.fordxr6turbo.com/forum/topic/79097-help-about-engine-replacement/#findComment-1203134 Share on other sites More sharing options...
Pazzo Donating Members 11,132 Member For: 14y 6m 26d Gender: Male Posted 28/02/12 06:46 AM Share Posted 28/02/12 06:46 AM How bad is your engine as ford sell new short motors for about $3000 Link to comment https://www.fordxr6turbo.com/forum/topic/79097-help-about-engine-replacement/#findComment-1203138 Share on other sites More sharing options...
Peever Donating Members 23 Member For: 13y 9m 11d Gender: Male Location: Townsville, North QLD Posted 28/02/12 06:51 AM Author Share Posted 28/02/12 06:51 AM The sump has pretty much disappeared... and the block has a hole on each side the engine will be taken out over the next week or so... Link to comment https://www.fordxr6turbo.com/forum/topic/79097-help-about-engine-replacement/#findComment-1203143 Share on other sites More sharing options...
Pazzo Donating Members 11,132 Member For: 14y 6m 26d Gender: Male Posted 28/02/12 06:57 AM Share Posted 28/02/12 06:57 AM As long head is ok look at the short engine option, being brandnew you know nothing is wrong. Link to comment https://www.fordxr6turbo.com/forum/topic/79097-help-about-engine-replacement/#findComment-1203149 Share on other sites More sharing options...
Impellor Member 835 Member For: 14y 9m 27d Gender: Not Telling Posted 28/02/12 07:13 AM Share Posted 28/02/12 07:13 AM (edited) The sump should be fine as long as its not leaking. BFII has stronger pistons, same rods as FG, but FG block is stronger than BF.But a stronger block is not going to make alot of difference when your throwing rods. Cheers Edited 28/02/12 07:14 AM by Impellor Link to comment https://www.fordxr6turbo.com/forum/topic/79097-help-about-engine-replacement/#findComment-1203167 Share on other sites More sharing options...
