Chattering Sound Under Load On Tune
astroinc
  • New Member
  • Member For: 20y 8m 25d
Hi ,
I was just wondering if anyone could tell me what I am hearing under load from the engine.
I have had a custom tune in the FG auto for about 6 months now which I have been very happy with. Last week when I was driving home, I was going up a slight hill when I noticed what sounded like diesel chattering or the sound when you are driving a manual in too higher gear at about 1.5-2K rpm, just before the gears changed down, then disappeared when the higher revs and lower gear kicked in. I was able to replicate the sound by locking in a higher gear while going up hills. It seems to disappear on level cruising and slightly appears when the current gear is starting to be loaded before kicking down. It was also about 35 degrees when I first noticed it, but has been doing it in the mornings around 20 degrees
The noise appears to come from the engine not the gear box.
Does anyone know what this could be? Any help would be greatly appreciated.
  • Moar Powar Babeh
  • Member For: 19y 2m 8d
does it sound like marbles rattling in a tin can? Sounds like it could be pinging or could also be an exhaust leak, either way stop driving it in a manner that causea the noise and get your tuner to look at it!
  • New Member
Thanks Guys, I have put it back to stock while I try some different fuel for a couple of weeks, then I will try the tune again to see if it was dodgy fuel. If its still there, I will book it into the tuner for a look. It also hasn't been boosting as hard as it normally does, could this be due to an exhaust leak before it reaches the turbo?
