  • Member For: 12y 4m 2d
You can actually take the two 10mm plates from the bottom of the spring pack and put them on the top. This has the same effect as adding 20mm lowering blocks
  • Member For: 11y 3m 11d
no you can not ,there is a locating pin on the top and when you use the two 10 mm spacers it would cover the pin to locate the diff to the springs .that would not be a
good idea sorry mate . I know as I was going to do the same ,lol
Edited by gunna
:facepalm: My mistake, when I did this it was on a set of pedders leaf springs and it was possible to swap from bottom to top. I wasn't clinking thearly.
9arhbfH.jpg?1
  • 3 weeks later...
  • New Member
  • Member For: 10y 4m 18d
you can take the whole leaf bracket apart and actually put the two plates ontop of the actual leaf cluster. You don't put it on top of the diff locating pin. I did it and it took about an hour to do boat. I had to unbolt the whole leaf pack and put the two peices ontop then bolt the pack back together
mine is a one tonner ,and when I bought the new leaf springs I had to pull them apart so that the bracket would not hit . and I tried to fit them on top but for some reason it did not work .but that was about two years ago . I know that I had to use the tonner springs bolt to go thru the centre of it so they would work for my ute
