  • Member For: 18y 11m 7d
you're right, way too many possibilities for anyone to give an accurate diagnosis, a sound clip may help but you may have to get your mechanic to listen to it live to get a good idea
  • Replies 29
  • You've changed man....
  • Member For: 14y 4m 7d
  On 22/02/2012 at 11:22 PM, ratter said:
Flywheels still come loose and give similar noises, ask stainless
I heard that
  • Member For: 15y 9m 26d
It sounds like a very common problem I have a ba but just fg running gear in mine and I now have this bloody noise which is called a roll over noise it comes from somewhere between your slave cylinder and flywheel when the car is at idle low rpm if you turn the steering wheel or put the ac on basicly put extra load on the car the noise will be more prominent.Once you put the clutch in it disappears because when you push down on the clutch there is load down there and everything is tight so it goes away let go of the clutch and it is back.Very common especially once you put a heavy duty clutch or once you put a short shifter any little mods just bring out the noise .I hate it just put a new moter and a tr6060 new clutch and I here this noise it kills me. I will get it fixed cause it shouldn't be there.
  • Member For: 14y 29d
Roll over noise is from the gear box mate. Not from the bell housing. It's a completely normal noise and can be dampened by adding more oil.
It's quite the opposit with the clutch in. With the clutch in the gearbox is disengaged. Therefore the lay shaft is not spinning inside the box and no rollover noise. The noise is louder with ac engaged because the engine slightly increases revs. Same with the power steering.
Edited by MX Dave
  • Dropping a turd
  • Member For: 17y 6m 7d
  On 23/02/2012 at 12:08 AM, Crashed said:
Gearbox rattle? Mine does it.
Has anyone put a twin plate clutch in your car?
yep std on mine, with some nice ceramic plates.
Mine has started making rattle noise now :(
At idle with ac on.
My whole zorst rattles like crazy. Gunna redo it from cabin back when do new tray.
