Fg F6 Manual Oil Change
ki11er 69
  • Member For: 13y 5m 10d
Im sure this has been talked about but I cant seem to find a striate answer.
I am have a 15000k service done tomorrow and want to change my gear box oil as I have heard that putting better grade oil in makes it smoother in the gear changes.
Also should I change the diff oil too.
I haven't done any mods yet but am planning to in the next 15000 I will only be chasing about 330rwkw.
Thanks for your advice.
  • Member For: 16y 6m 13d
Do your diff oil aswell, dont forget your diff gets a pounding , I used mainlube.
I used Transmax for the box and found it got a bit notchy with 4.85 then I droped about 500ml and it was OK after that, the rattle returned slightly but only when cold.
  • Member For: 17y 9m 3d
How much you guys paying for transmax? Supercheaps website say 75 for 4 litres but in store they said 135??
Don't know if it even come in 1 litre bottles?
  • Member For: 15y 1m 11d
Are you servicing your vehicle only at the recommend intervals as for most people you'd probably do it in between due to not covering 15000ks fast enough.
Its my daily drive I have done about 15000 since november I changed the engine oil at 7500km and am going to put sin 15 in it this time.
Was planning on only changing the diff at 30k and gear box every 30k from this service
