New Clutch
NitroTEE
  • Member For: 18y 8m 30d
my new mw3+ launches 3rd no worries :spoton:
ps im stainless... the guy that *beep* in first post mentioned
pss. I havnt really launched 3rd Mick... that's retarded
psss. the new version apparently remedies a knock noise some of you fg guys are getting on start up, from flywheel hitting starter motor.
:hammerhead:
just to correct something, the flywheel was not hitting the starter motor and causing a knocking noise, the flywheels were cnc cut including the ring gear teeth and then the teeth hardened, the hardening process was causing the starter to give some noise like the starter was hanging on, basically a resonance was occuring from ther hardening process, this has been rectified by a new flywheel that you remove and refit the original ring gear to the new flywheel.
  • You've changed man....
  • Member For: 14y 1m 30d
And yeh stainless I agree it was retarded my bad sh*t happens!, im still learning how to properly drive my car seeing as I had the zf before!
Haha. Im just takin the piss mate. Wont take ya loke to see the retarded things ive done posted all over the forum.
But yer, so far my mw feels like stock.
  • Member For: 13y 2m 2d
just checking quickly did any of you have the shudder issue when engaging the clutch at low revs with the stock clutch, and did the mal wood opt 3+ rectify this problem?
Edited by NitroTEE
haha im talking to myself a ltitle, after reading a few posts, im wondering could it just be the clutch slave cylinder? it only smelt like dogs balls when I did it, the clutch does not slip at all so when I accelerate full throltle in fith it contines to up in speed as well as revs. The only major issue is the loss of pressure!
I would greatly appreciate anyone helping me out haha becasue at the momment I was keen to spend my coin on suspension work but if the clutch needs to be replaced the coilovers will get postponed!
Cheers guys
Edited by NitroTEE
The gearbox has to come out to do a csc, would be wise to consider the clutch while it's out if you are going to be chasing any power increase in the future
  • Member For: 15y 1m 8d
I better start scraping the funds together for the mw3+ then sounds like the go to me. Anyone know shipping for something like that to NZ.
  • Member For: 13y 4m 14d
Ring Mal , you won't be able to ask him a question that he can not answer , Real easy to talk to as well .
Guys don't forget that he will also build a clutch to suit your needs not just what is advertised on his web site .
