peter_125 New Member 11 Member For: 13y 7m 9d Posted 18/02/12 07:08 AM Share Posted 18/02/12 07:08 AM Hey guys. I though it would do a wright up on how I made my moulded subwoofer box. I always wanted one that would fit in the right rear side of my bf's boot but I could only ever find left sided ones (They dont fit because of the factory amp), so since I broke my wrist and was off work I thought I would make my own. This was my first attempt at this and I have never fibreglassed before this so it may not be the perfect technique.You will need:- Masking take (blue painters tape is best as its less absorbent)- Tin foil- A few cheapo paint brushes- Plastic cups- Rubber gloves- Small measuring cup- Approx 2.5 x 1m off fibreglass matting and appropriate amount of resin- Catalist hardener- Resporator- Spandex,fleece of any stretchy material- Spray adhesive- Carpet- MDF- Glue- Time and moneyTools for the job:- Jig saw- Grinder or similar- DrillStep 1:Get your masking tape together and start taping up the area you want your box to be, overlapping your tape. Make sure you tape a bit further than you actually want your box to startStep 2:Once you have taped the area well with no carpet to be seen, its time to add foil. You dont neccisarily have to use the foil but it gives the extra layer of protection from resign soaking through and its easier to release. Cut the foil up in to manageable squares, using large squares in flat spots and smaller in tighter areas. Try to over lap them and tape down each side.Step 3:Time for fibreglass.First of all place plastic/newspaper around the area you are glassing to make sure none gets on the carpet, it will never come off. Then cut or rip up your matting into manageable squares, around 100x100mm (can be bigger for flat spots). Make a good pile of ripped up matting that you can access easily. Time to mix up the resign and catalyst. Read the directions as to how much hardener/catalyst ratio is needed, its usually between 2-5% depending on the tempreture, And make sure you have enough for the job you are doing. To give you an idea the first layer I did I used about 350ml. Grab your brush and start brushing on a thick coat of resign onto and area (not the whole thing) Then place a piece of matting over the top, then dab more resign over the top untill its trasparent. The reason you dab it on is because if you brush it you displace all the fibres and it makes a mess and creates air bubbles (bad). Continue this process overlapping each piece of mat you put on, and make sure you do this quick enough before your resign hardens up (I put to much hardener in the first time I mixed it, it would be easier to put less that whats recomended so you get enough time to get it right) and make sure you glass well past where you want to box to start. Once your first layer is all glassed up leave it an hour or so.Step 4:Do another layer using the same teqnique, then allow to dry for an hour or 2 (the longer the better in this case).Step 5:Now you can remove it from the boot. Make sure its dry and strong enough before considering it. Onces its out start removing the tin foil and tape (I sudgest you wear gloves while doing this). Some wont come off but that's shouldnt matter, its only the back.Step 6:Now add another 2/3 layers. Its heaps easier now its out of the boot. You can see in the picture about there is a few spots of missed, if you find these fix them up by doing a double layer over them.Layer 3Layer 4Step 7:Now your base is thick enough you can start cutting it into the shape you want. Some people say use a jig saw but I found it much easier to use a grinder with a cutting disk. Test fit it as your cutting to see how it fits.Step 8:Now its time to mount your sub ring. Refer to the box or measure you sub to get the correct mounting size. If you have the box it may have a template to trace around.I made the ring using a table router to get it perfectly round but im sure there are plenty of ways to do it. I used 16mm MDF for the ring, the thicker the better. Now when mounting the ring, make sure its not obstructing the sub and not poking out past where your spandex will go (later step). I found it easier to start at the bottom, so it stays there when you cut in your other braces. I just used scrap timber lying around the shed, you can use anything. To fix it to the back I used a screw and glued with PVA, I later removed the screws.Once your ring is mounted at the bottom sit it in the boot to see what angle the ring is facing before cutting your other braces.Step 9:This is where you wrap the box in a stretchy material. I used spandex, it was very easy to get tight.Use spray adhesive around the edges of your box, attach the spandex to the top/bottom and stretch over and around the box sticking it down to the edges. Make sure its VERY tight, if not it will cause plenty of problems later. If you decide you dont like the shape once the spandex is on, remove it, change the shape of your box and try again. I did it and found the top left and bottom left corners where far to sharp so I curved them with a grinder with a grinding disk. Make sure there are no wrinkles in the spandex and make sure its very firmly stuck down (I ran into trouble because I didnt stick it down well enough).It should look something like this.Step 10:Mix up resign and layer it over the spandex, don't push to hard and make sure it even, but not to thick or else it will sag.Here's where disaster struck with mine...By not sticking the spandex down properly it started to sag, come undone and masive wrinkles appeared. I managed to get most of it tight again while the resign was going off but some I couldnt get rid of. Once the resign hardened up I just used builders bog to fill up these wrinkles and it turned out perfect.Step 11:Now is a good time to test fit your box to see if it needs modification. Now to add a some layers over the resigned spandex once its hardened. Make sure you dont go over where the sub goes because it will make it difficult to cut out later. I did 3 layers total on the front.Step 12:You can now cut out the hole and the excess material at the back. I grinded the material off the back as it had resign on it it was fairly easy. To cut the hole open I just used a stanley knife. Once the hole is open and if you have some glass left over, inside the box join the spandex to the base, I did this for extra support. Give it a light sand removing any excess fibres and resign drips before carpetingStep 13:Time to carpet. Make sure the carpet you get it stretchy, or else you wont have a hope of getting it on properly (car audio shops sells the right stuff). The adhesive I sudgest using is the one pictured above. I bought it from a car audio shop and I can see why, it works perfectly.Spray the box and carpet and stretch it all over and around, it may be a battle but just keep stretching it untill all the wrinkles are gone. Then simply cut the hole out with a stanley knife.And that's it!The final product:Fits well and sound great.Let me know if I have left anything out or if you have any questions feel free to ask.Peter 5 Link to comment Share on other sites More sharing options...
knoles Donating Members 390 Member For: 13y 11m 3d Gender: Male Location: Port Hedland Posted 18/02/12 07:26 AM Share Posted 18/02/12 07:26 AM Great write up! How does the glass stick to the sub ring, is it just stuck there with the resin or do you reinforce it from behind or something? Obviously there's the wooden braces but is that all? Link to comment Share on other sites More sharing options...
peter_125 New Member 11 Member For: 13y 7m 9d Posted 18/02/12 07:38 AM Author Share Posted 18/02/12 07:38 AM thanks mate. Its just stuck there from the spandex on the front of it. I guess they work together, you screw threw the glass that's 4 layers thick that attached to the back and through the mdf that's braced fairly well 1 Link to comment Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 17y 8m 24d Gender: Male Location: Melbourne Posted 18/02/12 07:52 AM Share Posted 18/02/12 07:52 AM Great write up, this will give allot of people the confidence to have a crack on there own.Pinned. Link to comment Share on other sites More sharing options...
234Fpv Donating Members 522 Member For: 13y 7m 11d Gender: Male Location: Yeppoon qld Posted 18/02/12 08:05 AM Share Posted 18/02/12 08:05 AM Nice write up mate. I might even give it a goSent from my HTC Desire using my right hand Link to comment Share on other sites More sharing options...
Shyfrd Turboless Donating Members 5,992 Member For: 13y 11m 23d Gender: Male Location: Geelong, Victoria Posted 18/02/12 09:00 AM Share Posted 18/02/12 09:00 AM good stuff pete! will have to hear it in the flesh sometime soon its come up a beauty. craig 1 Link to comment Share on other sites More sharing options...
f6mark Member 2,908 Member For: 14y 5d Gender: Male Posted 18/02/12 09:46 AM Share Posted 18/02/12 09:46 AM Nice.. top job mate.. Link to comment Share on other sites More sharing options...
1NSANE Donating Members 279 Member For: 14y 9m 10d Gender: Male Location: South West Melbourne Posted 18/02/12 10:50 AM Share Posted 18/02/12 10:50 AM Just the one thing that I can suggest is to check after construction that it is air tight by filling it with water. I was surprised how much mine leaked when I did one.Ben 1 Link to comment Share on other sites More sharing options...
Goliath Member 383 Member For: 14y 7m 4d Gender: Male Location: Sydney Posted 18/02/12 12:29 PM Share Posted 18/02/12 12:29 PM Great write up mate, Not satisfied with the sub box I currently have in the boot, So may give this a shot down the road. Link to comment Share on other sites More sharing options...
Ss34tr New Member 19 Member For: 12y 7m 16d Posted 05/07/12 12:36 PM Share Posted 05/07/12 12:36 PM Great tut man, looks cool as, never played with fibreglass before though, may have to give it a crack. Link to comment Share on other sites More sharing options...
