Lowering The G6Et
Sam_boss260
  • Replies 31
  • Member For: 17y 8m 23d
:stupid:
The first bit anyway, SSL/SSSL is good without loosing too much ride quality.
  • Member For: 13y 21d
Re: Lowering a G6ET, just a little
Well, just to update this thread, I have done a bit more homework, and am amzed at the differing prices that I have been given.
I have gone round and asked that I would like the car lowered around 15mm. This is the recommendations and quotes that I have recieved.
Company 1 - For their own brand of springs, quoted me $900 drive in drive out with wheel alignment for 4 springs, that would drop around 35 - 40mm. They then tried to upsell me to a full set of their own coil overs for $2,600 !!
Company 2 - $595 drive in drive out with wheel alignment for 4 Kings springs, aiming at around 20mm to 22mm drop. Not sure if they are SL's all round, or SL up front and SSL in the rear.
Company 3 - $800 and something for front and rear King springs with wheel alignment, drive in drive out. He didn't write down the quote, as he changed it to quoting for the rear springs only in the end. So it was $547.73 for SSL's rear springs (front stays at stock) but he included "BA Rear Bump Stops" in the price. Note, labour was $150 and wheel alignment front and rear was $110.
Company 4 - SUPPLY ONLY - King Springs - Front SL's and Rear SSL's. $270 shipped to my door. I then need someone to fit and do a wheel alignment.
So the price difference is massive. If I go along with lowering the car, as I'm still not sure, I will go with the supply only - Company 4, and have them fitted here and get a wheel alignment.
Still cannot believe the price difference. Even if I get them supplied from Sydney, and paid $150 for fitting and $110 for a wheel alignment, I'm still better of by $65 !!
  • Carnage on the Garage Floor
  • Member For: 14y 9m 7d
Looking into this myself atm. Yes, the prices seem all over the place. Went to Kings factory today. Looked at the catalogue before hand and noticed no 'SL' listed. They said you can still get them, but the most common is SSL fronts as people complained about them not lowering the car enough. They still recommend SSL rears however. This combo should come out at 345 - 350mm centre of hub to guard. So, about 20-25mm drop.
The only thing I'm unsure of is the fronts. Probably will go with SL as I'd like the rake of the car to change from OEM. If I go the SSL's it will be the same - down at front and not level. All said, the two vary by 10mm.
Keen for someone that has done the SSL and SSSL to do measure up and post.
Less chance of stuffing the OEM shocks too with the SL's. If changing them then no problem.
with alignment?
I have SSL and SSSL with stock shocks. I have a 1 1/2 finger gap between my tyre and guard on 19's
Average sized fingers.
what is the centre of hub to under guard measurements?
Pedders quoted $630 today as a comparison.
