BF26TB Member 10 Member For: 14y 3m 3d Gender: Male Location: Eastern suburbs Syd City Posted 12/02/12 09:02 PM Share Posted 12/02/12 09:02 PM I know there is other threads about this but none on the BF, It's a BF2 ZF XR6T, I took it to my local mechanic and they put there scan tool on it, it only came up with one code P2105 (forced shut down) Throttle actuator control module. Due to electronic TB when the computer loses signal from the tb no matter the speed the car will shut down. It's done it at all speeds, idle, 110km/hr, 50km/hr, etc.I then took it to Ford, they put there scan tool on it and it came up with a heap of codes. They said put a new battery in it and clean the TB (which I had already done and it wasn't dirty). My mechanic seems to think it's a key/remote problem (I only have one key and a broken remote). I'm torn as I have sweet FA money as an apprentice I don't want to waste my money on mechanics and parts that don't fix the problem. Yesterday it was playing up so I unplugged the tps and throttle motor looms and blew them out and reconnected, then unhooked battery and hooked it back up, and it started first go, but then stalled after I stood on the go pedal. Oh it also has one of the original capa flash tuners on it, and it has only been on since the end of november last year.This morning I went to start it to go to work and it won't even kick, not even a little bit, not starter motor noise at all. The fuel pump primes and everything else works but won't start. I am going to buy a new battery on the way home from work today, and if it starts Im going to get a new key and remotes. But I mainly won't to know other peoples thoughts, especially if they have had this problem. Link to comment https://www.fordxr6turbo.com/forum/topic/78915-bf-xr6t-stalls-and-wont-start/ Share on other sites More sharing options...
Rosie Member 361 Member For: 18y 24d Posted 13/02/12 01:59 AM Share Posted 13/02/12 01:59 AM On 12/02/2012 at 9:02 PM, BF26TB said: I know there is other threads about this but none on the BF, It's a BF2 ZF XR6T, I took it to my local mechanic and they put there scan tool on it, it only came up with one code P2105 (forced shut down) Throttle actuator control module. Due to electronic TB when the computer loses signal from the tb no matter the speed the car will shut down. It's done it at all speeds, idle, 110km/hr, 50km/hr, etc.I then took it to Ford, they put there scan tool on it and it came up with a heap of codes. They said put a new battery in it and clean the TB (which I had already done and it wasn't dirty). My mechanic seems to think it's a key/remote problem (I only have one key and a broken remote). I'm torn as I have sweet FA money as an apprentice I don't want to waste my money on mechanics and parts that don't fix the problem. Yesterday it was playing up so I unplugged the tps and throttle motor looms and blew them out and reconnected, then unhooked battery and hooked it back up, and it started first go, but then stalled after I stood on the go pedal. Oh it also has one of the original capa flash tuners on it, and it has only been on since the end of november last year.This morning I went to start it to go to work and it won't even kick, not even a little bit, not starter motor noise at all. The fuel pump primes and everything else works but won't start. I am going to buy a new battery on the way home from work today, and if it starts Im going to get a new key and remotes. But I mainly won't to know other peoples thoughts, especially if they have had this problem.Sounds like it could be a number of things, but have a look at the Wires coming off the Throttle Body switch.They tend to 'sag' off the fitting and eventually break!- Very thin Wire.I have had this happen twice, with the same symptoms. Link to comment https://www.fordxr6turbo.com/forum/topic/78915-bf-xr6t-stalls-and-wont-start/#findComment-1195347 Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 15y 3m 14d Gender: Male Location: Christchurch, New Zealand Posted 13/02/12 02:03 AM Share Posted 13/02/12 02:03 AM With the fuel pump working and no starter noise at all, Id almost look at the key/transponder as it sounds like it was still immobilised. Link to comment https://www.fordxr6turbo.com/forum/topic/78915-bf-xr6t-stalls-and-wont-start/#findComment-1195349 Share on other sites More sharing options...
bionicxr6t05 Bronze Donating Members 2,216 Member For: 13y 9m 5d Gender: Male Posted 13/02/12 02:34 AM Share Posted 13/02/12 02:34 AM Sounds like a throttlebody or accelerator pedal if your in brisbane pm me I have test throttle and pedal Link to comment https://www.fordxr6turbo.com/forum/topic/78915-bf-xr6t-stalls-and-wont-start/#findComment-1195359 Share on other sites More sharing options...
BF26TB Member 10 Member For: 14y 3m 3d Gender: Male Location: Eastern suburbs Syd City Posted 13/02/12 11:20 AM Author Share Posted 13/02/12 11:20 AM I did have a look at all the wiring while it was apart and everything seemed fine.Yeah I am planning on getting new keys and remotes, need to get the ute there and don't want to pay for a tow unless I really have too.I'm in Sydney east, thanks for the offer though bionic Link to comment https://www.fordxr6turbo.com/forum/topic/78915-bf-xr6t-stalls-and-wont-start/#findComment-1195663 Share on other sites More sharing options...
