6speedXR8 Mal Wood Automotive Member 537 Member For: 21y 9m 7d Location: WARWICK QLD Posted 23/02/12 09:45 AM Share Posted 23/02/12 09:45 AM Well at long last we have the option 3 to fit the T5, what we had to do was make a new sandwich plate that is 4 mm thick (this goes between the bellhousing and the engine) and then step the flywheel face closer to the ring gear and it all fits now.We can now offer the ACE 11'' option 3 to fit the T5 at $1600 and that gives you a New Sandwich Plate, New Billet Steel Flywheel, New 11'' clutch assembly, New alloy CSC, New flywheel bolts and a spigot bearing.This will be perfect for the guys out there with a T5 and wanting a better clutch while saving for a T56 upgrade. Mal Wood Link to comment Share on other sites More sharing options...
MX Dave Donating Members 545 Member For: 13y 8m 19d Gender: Male Posted 23/02/12 01:24 PM Share Posted 23/02/12 01:24 PM Wish this was available 2 months ago^^^ haha nice job mal! Link to comment Share on other sites More sharing options...
josh_hammy Member 192 Member For: 13y 27d Gender: Male Location: Perth, WA Posted 23/02/12 02:15 PM Author Share Posted 23/02/12 02:15 PM Well at long last we have the option 3 to fit the T5, what we had to do was make a new sandwich plate that is 4 mm thick (this goes between the bellhousing and the engine) and then step the flywheel face closer to the ring gear and it all fits now.We can now offer the ACE 11'' option 3 to fit the T5 at $1600 and that gives you a New Sandwich Plate, New Billet Steel Flywheel, New 11'' clutch assembly, New alloy CSC, New flywheel bolts and a spigot bearing.This will be perfect for the guys out there with a T5 and wanting a better clutch while saving for a T56 upgrade. Mal WoodThis seems like the path I wanna go down ASAP!!! Just a few quick ones.-How much power is this clutch rated to? -can you get this kit with the option 3+ clutch? Which I think is good for about 410rwkw??-if I was to buy this kit, have it installed, then a few months down the track purchase T56 from Malwood, how much $ am I looking at to buy all the gearbox etc? Link to comment Share on other sites More sharing options...
OED666 Member 129 Member For: 18y 6m 1d Gender: Male Location: Gold Coast, Qld Posted 27/02/12 10:09 PM Share Posted 27/02/12 10:09 PM The Option 3 is rated to hold 350RWKW, and Option 3 Plus 410RWKW. We can supply the Option 3 Plus for the T5 as well, which will be around $1850. The cost on the T56 upgrade is $3890, for all the components required for the conversion.http://www.malwoodauto.com.au/index.php?page=ford Link to comment Share on other sites More sharing options...
