Tim Member 142 Member For: 16y 9m 24d Posted 11/02/12 09:50 AM Share Posted 11/02/12 09:50 AM HiMy FG Turbo wont start. Went to drive it this afternoon and when I started the car it stalled straight away. The car is auto. It did this twice and then no starter motor at all. I noticed the radio had become locked, I supected a stuffed battery. The battery voltage was a little low so I tried a jump start but still nothing from the starter motor. The jumper cables were rusty so I went to the next option. Swapped in the battery from my boat and still nothing from the starter motor. Battery voltage from the boat battery is good. I have made sure it was in park unlike the popular car wont start thread. Also tried neutral.The starter motor is not making any noise but there are relays clicking over when the key is turned to the on position. Lights, horn, central locking etc all seem to work. Can any body shed some light on what the problem may be? Link to comment https://www.fordxr6turbo.com/forum/topic/78896-fg-turbo-wont-start/ Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 5m 15d Gender: Male Location: SE Melbourne Posted 11/02/12 10:05 AM Share Posted 11/02/12 10:05 AM Check the relevant fuses to see if they are ok. Link to comment https://www.fordxr6turbo.com/forum/topic/78896-fg-turbo-wont-start/#findComment-1194637 Share on other sites More sharing options...
Aust_Monty Member 26 Member For: 13y 6m 1d Gender: Male Location: Toowoomba Posted 11/02/12 11:38 AM Share Posted 11/02/12 11:38 AM Call RACQ/V/W etc Link to comment https://www.fordxr6turbo.com/forum/topic/78896-fg-turbo-wont-start/#findComment-1194675 Share on other sites More sharing options...
Tim Member 142 Member For: 16y 9m 24d Posted 11/02/12 12:12 PM Author Share Posted 11/02/12 12:12 PM Will check the fuses in the morning. Thanks Paulie. Link to comment https://www.fordxr6turbo.com/forum/topic/78896-fg-turbo-wont-start/#findComment-1194685 Share on other sites More sharing options...
nitro xr6 turbo Banned 185 Member For: 13y 5m 23d Gender: Male Location: perth wa Posted 11/02/12 03:14 PM Share Posted 11/02/12 03:14 PM have you got a spare key? try that mate.cheers. Andy Link to comment https://www.fordxr6turbo.com/forum/topic/78896-fg-turbo-wont-start/#findComment-1194718 Share on other sites More sharing options...
Tim Member 142 Member For: 16y 9m 24d Posted 11/02/12 10:52 PM Author Share Posted 11/02/12 10:52 PM (edited) I had tried the spare key yesterday with no luck thanks Andy.There were no fuses blown but after I pulled them and checked them all the car started fine. Must have been one with a bad contact. Hopefully it is that simple as next month I am going on a 2000km road trip and I really dont wont to get stranded out the back of beyond. Edited 11/02/12 10:59 PM by Tim Link to comment https://www.fordxr6turbo.com/forum/topic/78896-fg-turbo-wont-start/#findComment-1194748 Share on other sites More sharing options...
Tim Member 142 Member For: 16y 9m 24d Posted 02/12/12 07:08 AM Author Share Posted 02/12/12 07:08 AM The same problem has struck again. Pulled and refitted all the fuses and no luck this time. Going to have to call roadside service. Link to comment https://www.fordxr6turbo.com/forum/topic/78896-fg-turbo-wont-start/#findComment-1332734 Share on other sites More sharing options...
Glouva1 Donating Members 654 Member For: 13y 10m 2d Gender: Male Location: Surrey Hills, Melbourne Posted 02/12/12 07:15 AM Share Posted 02/12/12 07:15 AM My car has done exactly the same. Behaves like you are trying to start it in drive instead of park. It did it about 8 or 9 times. Nizpro checked everything and could not find anything wrong with it. Has not done it for about 5 months now so maybe sorted itself out. Had us all confused why though. Link to comment https://www.fordxr6turbo.com/forum/topic/78896-fg-turbo-wont-start/#findComment-1332737 Share on other sites More sharing options...
phantom xr6t Talks Cheap, Let's Race Member 596 Member For: 18y 5m 21d Gender: Male Location: Atherton, FNQ Posted 02/12/12 07:34 AM Share Posted 02/12/12 07:34 AM Sometimes my BA auto wont start, if I give the shifter a tap forward in park it will start, must be a problem with the neutral cut switch not engaging in park sometimes Link to comment https://www.fordxr6turbo.com/forum/topic/78896-fg-turbo-wont-start/#findComment-1332745 Share on other sites More sharing options...
bionicxr6t05 Bronze Donating Members 2,216 Member For: 13y 9m 9d Gender: Male Posted 02/12/12 08:52 AM Share Posted 02/12/12 08:52 AM The fact it started and then stalled is a bit sus... Make sure the starter solenoid is getting cranking signal, if its ok see of you can turn the engine over by hand (21mm socket and breaker bar/ 1/2 drive ratchet on balancer bolt) Link to comment https://www.fordxr6turbo.com/forum/topic/78896-fg-turbo-wont-start/#findComment-1332802 Share on other sites More sharing options...
