joe@cms Member 129 Member For: 15y 10m 22d Gender: Male Posted 07/10/12 08:14 AM Share Posted 07/10/12 08:14 AM with out a dout its up the tuner & what he feels confortable with & your right about what goals you are tring to achieve ... an 8 sec or better car then aftermarker is the way to go, but IMO anything to that point I'd prefer the Ford unit & the BF more so, I've been using/ tuning the EECV & EECIV with Tweecer & Moates & the SCT eliminate chips for years, the only thing that lets me down with the earlier modles is the condition of the wiring which can be frustating due to the age of the loom, pins & how corrosion attacks them, then you have to go with an aftermarket as then we look at cost.. Link to comment https://www.fordxr6turbo.com/forum/topic/78885-any-aftermarket-ecus-that-will-run-the-xr6t-yet/page/5/#findComment-1306012 Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 9m 29d Gender: Male Location: OZ Posted 07/10/12 08:55 AM Share Posted 07/10/12 08:55 AM Scaling a t-MAP can only be done via dodgy manipulation of accessible tables.....one can't re-scale the sensor calibration. I can only imagine how confused the PCM must get without a correct rescale, considering the t-MAP calibration is one of the most important in the ford PCM. A 3.5 bosch t-MAP on reads down to -15 inHG at sea level iirc so I'd be sticking with a 3bar as they go down to -24 inHG. Anyway not starting a $hitfight but I reckon a ford engineer would cringe at the thought of this! Link to comment https://www.fordxr6turbo.com/forum/topic/78885-any-aftermarket-ecus-that-will-run-the-xr6t-yet/page/5/#findComment-1306028 Share on other sites More sharing options...
joe@cms Member 129 Member For: 15y 10m 22d Gender: Male Posted 07/10/12 10:03 AM Share Posted 07/10/12 10:03 AM intresting & yes the ford engineer would be pulling his hair out, but when I was told that I cant do the same on a AU s11 with the std map cuting boost out at 3 psi then worked out the scaling at the point that I wanted to see, was then able to use the SCT software to provide upto 14psi boost not that I wanted it & it provided acuate fuel & spark from logging, well to say I was happy that It could be done was an understatment, but now days what we do is wire up an Bseries map if we need to go further, I'm just a mechanic that's inquisitive & makes mistakes like everyone else.. Link to comment https://www.fordxr6turbo.com/forum/topic/78885-any-aftermarket-ecus-that-will-run-the-xr6t-yet/page/5/#findComment-1306086 Share on other sites More sharing options...
A1 Automotive New Member 11 Member For: 10y 4m 15d Posted 14/02/15 11:56 PM Share Posted 14/02/15 11:56 PM Sorry to dig up and old topic, but better than starting a new post. How does one get around the Canbus issues running and after market ECU in a BA falcon? Link to comment https://www.fordxr6turbo.com/forum/topic/78885-any-aftermarket-ecus-that-will-run-the-xr6t-yet/page/5/#findComment-1530254 Share on other sites More sharing options...
RIP85 REST IN PEACE V8 Donating Members 469 Member For: 17y 15d Gender: Male Location: Woodridge on the park bench Posted 15/02/15 01:59 AM Share Posted 15/02/15 01:59 AM https://www.facebook.com/MicksMotorsport/posts/872613476136925I have my tuner looking into this as I want to run my flex sensor with a computer that can talk to it Link to comment https://www.fordxr6turbo.com/forum/topic/78885-any-aftermarket-ecus-that-will-run-the-xr6t-yet/page/5/#findComment-1530278 Share on other sites More sharing options...
A1 Automotive New Member 11 Member For: 10y 4m 15d Posted 15/02/15 05:59 AM Share Posted 15/02/15 05:59 AM That's a mean set up, wonder how he went about piggy backing it to trick the factory ECU 1 Link to comment https://www.fordxr6turbo.com/forum/topic/78885-any-aftermarket-ecus-that-will-run-the-xr6t-yet/page/5/#findComment-1530305 Share on other sites More sharing options...
