ratter Member 6,793 Member For: 18y 10m 22d Gender: Male Location: @ my laptop Posted 01/08/12 08:20 AM Share Posted 01/08/12 08:20 AM but were you using to control the noz? Link to comment https://www.fordxr6turbo.com/forum/topic/78885-any-aftermarket-ecus-that-will-run-the-xr6t-yet/page/3/#findComment-1273510 Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 9m 10d Gender: Male Location: OZ Posted 01/08/12 09:07 AM Share Posted 01/08/12 09:07 AM it was a genuine question though, I think the wolf is a low level ecu and except for possibly top of the line motecs, the motec would be inferior, but just wanted calrification in case I'm incorrectActually is the software that is the limiting factor....not the ECU itself. My bad.Ratter do you know why SCT doesn't have access to scaling the t-MAP sensor? It's one of the few short falls of the software in my opinion. Link to comment https://www.fordxr6turbo.com/forum/topic/78885-any-aftermarket-ecus-that-will-run-the-xr6t-yet/page/3/#findComment-1273527 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 10m 22d Gender: Male Location: @ my laptop Posted 01/08/12 09:44 AM Share Posted 01/08/12 09:44 AM have no idea, possibly they think we do not need access to it like they thought we did not need to adjust for hi stalls a while back.Could be a good question for Herrods or on the sct forum Link to comment https://www.fordxr6turbo.com/forum/topic/78885-any-aftermarket-ecus-that-will-run-the-xr6t-yet/page/3/#findComment-1273531 Share on other sites More sharing options...
stee3 Member 194 Member For: 13y 9m 24d Posted 02/08/12 12:51 AM Share Posted 02/08/12 12:51 AM what advantages in using the wolf and the motec?have no idea, possibly they think we do not need access to it like they thought we did not need to adjust for hi stalls a while back.Could be a good question for Herrods or on the sct forumWOLFs may have been a lower level ECU a few years back but it’s not the case any longer and hasnt been for a while. I was only sighting WOLF as one exmaple. These are many advantages of using an aftermarket ECUs especially the newer geneartion ECUs. For me the main one being you don’t need to load a tune into a flash tuner box and then load it into the car then do the same process over and over and over again. Most aftermarket ECUs can be tuned in real time. On the flip side the standard ECU is a cheaper option to tune for a customers car from a workshop perspective for small to med performance level application but not really the best solution for a retro fit.Advantages of using an aftermarket ECUtune in real timefit a larger MAP sensor easily (Normally they have one already fitted inside ECU)ability to run low and high impedance injectorslaunch Controlauxiliary controlability to run a cable throttle body which also means a larger TBThese are just a few off the top of my head. I also called Herrod about the t-map sensor calibration a few months back they were not sure how to do this either. Link to comment https://www.fordxr6turbo.com/forum/topic/78885-any-aftermarket-ecus-that-will-run-the-xr6t-yet/page/3/#findComment-1273694 Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 9m 10d Gender: Male Location: OZ Posted 02/08/12 01:04 AM Share Posted 02/08/12 01:04 AM Some good points. Interesting about the t-MAP. It's a software thing, Headsex said he has been able to do the re-calibration via his software so I'm assuming it can be done. If they can hack the zf, the sensor calibration would be a walk in the park. Like ratter said....it might just need some pushing like the stall issues of the past. Link to comment https://www.fordxr6turbo.com/forum/topic/78885-any-aftermarket-ecus-that-will-run-the-xr6t-yet/page/3/#findComment-1273696 Share on other sites More sharing options...
d rangd Member 341 Member For: 16y 5m 2d Posted 01/09/12 07:18 AM Share Posted 01/09/12 07:18 AM mines running an autronic sm4 with 500r cdi...wasnt any trouble when it was installed with te right hands. I got rid of the vct as it was f*cking up. runs wicked now. its an expensive idea but 1 Link to comment https://www.fordxr6turbo.com/forum/topic/78885-any-aftermarket-ecus-that-will-run-the-xr6t-yet/page/3/#findComment-1288399 Share on other sites More sharing options...
Bara58 Donating Members 116 Member For: 12y 9m Gender: Male Location: Bowen, Qld Posted 21/09/12 03:15 AM Share Posted 21/09/12 03:15 AM ViPec V88 = cats meow Link to comment https://www.fordxr6turbo.com/forum/topic/78885-any-aftermarket-ecus-that-will-run-the-xr6t-yet/page/3/#findComment-1298148 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 2m 11d Gender: Male Location: SW Sydney Posted 21/09/12 03:23 AM Share Posted 21/09/12 03:23 AM Cats meow? Link to comment https://www.fordxr6turbo.com/forum/topic/78885-any-aftermarket-ecus-that-will-run-the-xr6t-yet/page/3/#findComment-1298153 Share on other sites More sharing options...
relentless xr6 Member 363 Member For: 14y 4m 14d Gender: Male Location: Sydney Posted 02/10/12 04:58 AM Share Posted 02/10/12 04:58 AM can you run a 2 step off the transbrake using standard ford pcm one that's pops off and make it look like your motor is exploding I wish someone would do a right up on how to install a haltech or motec or put a link up for me. Link to comment https://www.fordxr6turbo.com/forum/topic/78885-any-aftermarket-ecus-that-will-run-the-xr6t-yet/page/3/#findComment-1303373 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 2m 11d Gender: Male Location: SW Sydney Posted 02/10/12 06:40 AM Share Posted 02/10/12 06:40 AM I'm pretty sure you need a clutch for a "2 step"The transbrake is doing what the 2 step will anyway. Both items are there to build boost while the car is stationary. The t/brake locks first and reverse gear together to load up the motor and build boost. The 2 step creates sort of a rev limiter for the motor to hit at a pre-defined rpm which will also create load and build boost. Link to comment https://www.fordxr6turbo.com/forum/topic/78885-any-aftermarket-ecus-that-will-run-the-xr6t-yet/page/3/#findComment-1303407 Share on other sites More sharing options...
