  • Member For: 17y 5m 18d
Torque is derived from power as well as your wheel sizes and stuff...hard to give accurate torque figures I believe? Even worse than rwkw between dynos? Someone correct me if I'm inaccurate here.
Anyway a power curve that is suddenly steep will still light up tyres on lower power levels I'd imagine.
If it matters, my torque says it hits about 650Nm, see graph of curve here:
  • 2 weeks later...
  • Member For: 13y 11m 1d
Hi guys
What's the go with fitting the invos?
I'm seeing different pics on the intaweb regarding their orientation. I know they're not directional, but does it make a diff running the channels on the outside as oppossed to the inside?
Thanks.
They have outside embossed on the tyre sidewall. You can run them either direction, but the fitters must fit the outside of tyre...to the outside of rim (shock horror). Can still do the full figure 8 swap.
Edited by -SteveR-
  • Member For: 22y 1m 12d
In the 245/35/zr19 the Nitto Invos come in two treadwears : the 93W = 260 and the 93Y = 220
I am looking for a full 8mm tread depth tyre with around a low 200 Treadwear and the 245/35/zr19 93y looks like the way to go. The ones supplied by Taleb seem to be 93w
The question is does anyone stock them here (Taleb?)
Edited by turbotrana
