biddie_fiddler [IMPULSIV3] Donating Members 1,374 Member For: 5y 10m 8d Gender: Male Location: Perth, WA Posted 05/02/22 07:26 AM Share Posted 05/02/22 07:26 AM Reviving a very old thread after doing some digging on the forums for oil pressure values. My brother just called me asking if 150psi on his oil pressure gauge is normal..... I really don't think that is. At all! This is him cruising on the freeway too. For reference, he has a built motor, with billet pump gears and a worked pump housing. My guess on oil is some form of a Castrol 10w-40. It is a very hot day today, in the high 30s. He's thinking it could be a faulty sensor for the oil pressure gauge. I'm not so sure. I'm gonna put a scanner on it when I can to see if there's any codes. Any ideas on this? Is this concerning? Could too much oil cause this? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,199 Member For: 16y 9m 27d Gender: Male Location: Melbourne Posted 05/02/22 07:31 AM Share Posted 05/02/22 07:31 AM either a faulty sensor or the oil pump didn't have a relief added to it... probably won't hurt too much, realistically, as the pressure in the cylinders is higher than that, just (well, it should be)... but something to take to the tuner to see what's going on is definitely a good course of action. Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,097 Member For: 10y 7d Gender: Male Location: South Australia Posted 05/02/22 07:39 AM Share Posted 05/02/22 07:39 AM For engines running over 35psi of boost it is recommended to run a high pressure relief spring (110psi+) and sometimes the pump will have a teeny weeny little bitty bolt that can raise the pressure further. There is a chance that the pump has had this done and will be running all kinds of pressure...all kindzzzz. Otherwise it could be a faulty gauge etc. 3 minutes ago, k31th said: the oil pump didn't have a relief added to it Yeah nah it's part of the casting. You'd have hundreds of psi if there wasn't a relief circuit. That's why housing crack, cos the housing is subject to the pressure before it bypasses the relief circuit. 1 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,199 Member For: 16y 9m 27d Gender: Male Location: Melbourne Posted 05/02/22 07:51 AM Share Posted 05/02/22 07:51 AM I forgot preface "relief added to it" with "appropriate"... my bad. 1 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,097 Member For: 10y 7d Gender: Male Location: South Australia Posted 05/02/22 07:54 AM Share Posted 05/02/22 07:54 AM Eh must be one of those weeks ay?! 1 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,199 Member For: 16y 9m 27d Gender: Male Location: Melbourne Posted 05/02/22 07:54 AM Share Posted 05/02/22 07:54 AM as is always said, the best way to get the correct information on the internet is to post the wrong information and somebody will surely come and correct it 1 Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,097 Member For: 10y 7d Gender: Male Location: South Australia Posted 05/02/22 08:08 AM Share Posted 05/02/22 08:08 AM Ok lets test this theory, here's tonight's lotto numbers 5 8 15 23 25 19 1 Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,199 Member For: 16y 9m 27d Gender: Male Location: Melbourne Posted 05/02/22 08:14 AM Share Posted 05/02/22 08:14 AM did Link to comment Share on other sites More sharing options...
biddie_fiddler [IMPULSIV3] Donating Members 1,374 Member For: 5y 10m 8d Gender: Male Location: Perth, WA Posted 05/02/22 08:32 AM Share Posted 05/02/22 08:32 AM FFFFFFFFFFFSSSS He called me and goes "so I removed the gauge and wiggled the connector at the back and now it's fine" Are you fkn joking me. Second confirmation the gauge and/or sensor is I <3 Bananased, he turned the car to acc and the gauge was reading between 70 and 100psi. 🤦♂️ Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,097 Member For: 10y 7d Gender: Male Location: South Australia Posted 05/02/22 08:40 AM Share Posted 05/02/22 08:40 AM I recently fitted an oil line kit supplied by the customer. The parts were anodized so when I fired it up there was an oil light. Pulled the whole thing apart again to diagnose and ended up having to run a wire to earth to get a proper oil pressure signal. That was a couple of hours I'll never get back 1 Link to comment Share on other sites More sharing options...
