Engine Rebuild
XR64LT
  • Member For: 17y 1m 10d
Ok so im sure this has been answered many times before but just curious to know whats needed for a reliable engine rebuild. So I seen spool imports have a rebuild kit for $2195 which includes spool rods, cp forged pistons, head gasket, alc main bearings and alc big end bearings. From what I can gather I would also need a billet gear oil pump. Anything else im missing?
Hahaha yeah I know, posted that from my iphone cause the internet was going abit slow and couldnt stand waiting for it to load. Will have a proper look on my computer. I guess ill only go as much as the standard turbo will go. Driving the car only once or twice a week I tend to just cruise, with some wot from time to time and I might even take it to sydney to see what it could do.
  • Member For: 18y 8m 22d
Balancing
Rings to suit
Engine rebore and recommend line boring
Hot tank clean
Block crack tested
Block deck height checked/machined
Crank Grind or linish
Crack testing crank
Timing chain
Timing chain guides
Timing Chain Tensioner
Rear Main Oil seal
Timing Case oil seal
Sump gasket
Timing case gaskets
Head Bolts
Head overhaul
Rocker cover gasket
Rocker cover seals for spark plug wells
Cam phaser seals
Inlet manifold gasket
Exhaust manifold gasket
Welsh plugs
If you going to do it, do it properly
  • Member For: 17y 8m 24d
Give 10k+ to a good engine builder, job done.
Unless your after huge power or want it for drag racing etc it's not worth it IMO. Just get an F6 short and get ford to bolt it on.
Will be reliable handle 400 if tuned well and will drive/sound the same as your current one.
It's the labour part that gets ya the actual parts arnt that bad.
  • 3 weeks later...
