russxr6t Member 18 Member For: 13y 3m 11d Posted 03/02/12 12:23 PM Share Posted 03/02/12 12:23 PM Hey all,So I know there's a few of these threads going around and I've searched and searched and I think I'm just making myself more confused. Basically I want to build a daily that I can take to the drags and with some practise run atleast a 13(a high 12 would be nice). I would aim for an 11 but I know the driveline mods needed are probs out of my budget(for now!). Budget is 3k-7k MAX depending on what I get...Basically aiming as cheap as can reliably. The Car: BF mk 2(08/06) XR6 TurboMods so far are minimal being:Bilstein coilovers all round.Photo is of when I got it though will update when I get home!Just put the earls turbo oil filter on and ditched the old one as recommended here! Glad I did after seeing it.So the questions I have are:Intercooler kits - I know what's out there PW,Plasmaman ect but what do I need to avoid losing power at my goals? I can't find an answer apart from don't get a monza or f6 cooler. I want to do it properly so if I need a stage 3 I will buy it but if stage 1 will be safe then great!Injectors - What brand and size? Some say get the biggest so you can power up later but how big? I was thinking of going Siemens here.Exhaust - Pretty easy one from reading I'm thinking the cat, centre muffler removal and bigger dump will be enough.(Size?)Fuel Pump - ???? Here as I've been given mixed ideas some say you NEED a surge tank, other just upgrade the pump.Tune and xcal3 - No brainer on xcal 3 and will probably head to Monsta Torque for tune(Heard nothing but good things).Sorry for the novel, but I think every persons needs are different so let me know what you think please! Want to start collecting parts asap so I can get it tuned. Just finished servicing everything I could think of to make it ready. Link to comment Share on other sites More sharing options...
Henz Tampon inserted, Auto Acquired, next purchase a new handbag Donating Members 9,946 Member For: 16y 9m 28d Gender: Male Location: Vic Posted 03/02/12 12:29 PM Share Posted 03/02/12 12:29 PM Get a really good cooler kit, plazmaman or PW. InjectorsIntank4" dump + cat. Xcal and tune. Will make over 300 easily and easy 12s, high 11s with good tyres. Link to comment Share on other sites More sharing options...
russxr6t Member 18 Member For: 13y 3m 11d Posted 03/02/12 12:46 PM Author Share Posted 03/02/12 12:46 PM Thanks for the reply Henz! Noticed you have the surge tank I mentioned, did you get that when you went past 300rwkw? Don't want to be sucking air...Plus you went for the biggest 1000hp cooler I was thinking about the 800hp? Should be enough yeah? Oh yeah and just 60lbs Siemens aswel.Reason I'm thinking about cooler choice is the standard one gives me MASSIVE lag once the engine goes past 1/4 on the temp guage(don't drive it hard until then) on a hot day mostly. But it's that bad doesnt even feel like the turbo's doing anything. Want the right one. Link to comment Share on other sites More sharing options...
russxr6t Member 18 Member For: 13y 3m 11d Posted 03/02/12 12:56 PM Author Share Posted 03/02/12 12:56 PM (edited) Guessing you got a 12PSI Actuator which I shouldnt really need for 300??This kit is the one im thinking of https://www.plazmaman.com/shop/index.php?action=item&itemId=209 once I add fitting price the plenum is probably out of budget sucks its so sexy. Will get a quote now I know what I want, thanks for your help. Edited 03/02/12 01:06 PM by russxr6t Link to comment Share on other sites More sharing options...
Henz Tampon inserted, Auto Acquired, next purchase a new handbag Donating Members 9,946 Member For: 16y 9m 28d Gender: Male Location: Vic Posted 03/02/12 01:47 PM Share Posted 03/02/12 01:47 PM You don't need a surge tank but, but you will have to keep the tank over 1/2 all the time. The 800hp cooler is plenty good for your needs. Steal some ideas from ideas from Tonyv's bf2, he has plazmaman 800hp, bolt in dump & cat, injectors, intank and tune and does high 11s. Link to comment Share on other sites More sharing options...
rbjet Skid Machine Donating Members 1,640 Member For: 13y 7m 24d Gender: Male Posted 03/02/12 08:14 PM Share Posted 03/02/12 08:14 PM Yeah mate, make sure you get a decent cooler. As soon as it's on you'll notice that the car will not lose power anymore when it's hot. I just did bosch injectors, waste gate actuator, high flow cat and removed middle muffler, Rapid V3 cooler and that was about it. I made 290 and that was on a 30 degree day on 12psi.The tuner said I'd need a cat back or another pound of boost to make 300 but I left it as is as I don't want to demolish the 4spd.You should be able to make 300 for about $3000 I reckon. Link to comment Share on other sites More sharing options...
russxr6t Member 18 Member For: 13y 3m 11d Posted 04/02/12 09:53 AM Author Share Posted 04/02/12 09:53 AM Sweet, thanks a lot for the replies. I just sent Rob an e-mail so see what he says.If it comes in under 4 grand il do it tomorrow if it's over it might be another couple of swings away I've got a goal on my mortgage to get to! One thing though I wasn't going to do the wastegate actuator as was hoping to keep it on or below 12PSI anyway...Isn't that a $1000 item??? Link to comment Share on other sites More sharing options...
XtRmn8 570Nm @1800rpm Donating Members 2,441 Member For: 21y 3m 26d Gender: Male Location: Perth, WA Posted 04/02/12 10:19 AM Share Posted 04/02/12 10:19 AM If you have any mechanical knowledge and can fit the parts yourself you will save a packet. Link to comment Share on other sites More sharing options...
russxr6t Member 18 Member For: 13y 3m 11d Posted 04/02/12 10:35 AM Author Share Posted 04/02/12 10:35 AM Got some basics it's time that's not on my side maybe a day free max in my rnr time(I only get 4.5 days/16days) Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 3m 25d Gender: Male Location: Perth Posted 04/02/12 04:55 PM Share Posted 04/02/12 04:55 PM Dont be afraid too give Simon at XFT a call too discusses your goals and budget. Link to comment Share on other sites More sharing options...
