UBA Donating Members 212 Member For: 13y 2m 2d Gender: Male Posted 12/01/12 03:47 AM Share Posted 12/01/12 03:47 AM (edited) BA XR6 TURBO QUOTEThe Exhaust system is $2750 fitted, which involves removal of your std system, fitment of the Turbo back system & modifying the Turbo heat shield to suit. The exhaust system is constructed of 304 stainless steel, it has a 4” dump pipe and hi flow catalytic converter & 3.5” from the cat back.Upgraded Valve spring & retainer set are $495 plus $770 to fit as this is a very Labour intensive job. The upgraded Turbo actuator is $185 plus $350 to fitUpgraded high flow Bosch fuel injectors ($120 each) are $720 plus $240 to fitThe only other essential upgrades before commencing the dyno tune is to upgrade the factory fuel system. We can supply and fit a genuine Walbro 550Hp fuel pump which will ensure consistent fuel delivery and avoid any dangerous lean out conditions that can cause serious damage to engine internals. To supply and fit a Walbro fuel pump is $360.ECU tune is a complete Custom Dyno Tune carried out by re-flashing your standard ECU and making it fully programmable. This is the only guaranteed way to get the most reliable power, torque & drivability there is out of your car, whilst still maintaining all of the factory safety features. We tune from full power to cruise & everywhere in between, modifying fuel, ignition, boost, VVT, throttle mapping and many other engine control parameters. Other workshops just “Flash” your car without putting it on the Dyno and hope for the best! This is a very risky option as critical engine parameters are not checked to ensure they are within safe limits. The ECU tune is priced at $1195- irrespective of how long it takes to achieve the desired results as the car is often on the Dyno for 3-4 plus hours to get everything 110% spot onWith these mods you should see around 50-60Kw Power increase & around 60% increase in torque! Total $7065what do u think of this quote Edited 12/01/12 05:06 AM by Dagabond Link to comment Share on other sites More sharing options...
gsd112 Donating Members 604 Member For: 14y 5m 18d Gender: Male Location: Penrith Posted 12/01/12 03:56 AM Share Posted 12/01/12 03:56 AM (edited) If I was you I would source the parts yourself and get whatever tuner to fit them, you will save heaps doing it that way. Where are you based? what car ba-bf or fg?Also my valve springs were $ 395 for the springs and $550 to fit. Edited 12/01/12 04:01 AM by gsd112 Link to comment Share on other sites More sharing options...
freeze_dk I am dissatisfied with my current employment situation Donating Members 8,610 Member For: 18y 4m 26d Gender: Male Posted 12/01/12 03:58 AM Share Posted 12/01/12 03:58 AM First of all how much power do you want? Link to comment Share on other sites More sharing options...
UBA Donating Members 212 Member For: 13y 2m 2d Gender: Male Posted 12/01/12 04:01 AM Author Share Posted 12/01/12 04:01 AM id be happy with 280rwkw and up !! Link to comment Share on other sites More sharing options...
MiKa Donating Members 4,243 Member For: 18y 6m 2d Gender: Male Location: Melbourne, VIC Posted 12/01/12 04:02 AM Share Posted 12/01/12 04:02 AM Depends on what brand everything is really..If they are installing an Xforce exhaust, then obviously its way overpriced, but if its a CES than they are a fairly expensive exhaust in the first place... Vsprings could be done cheaper, injectors IMO seem expensive get a set of siemens and $240 to fit?? Does the tune include an X3? if not then its a bit on the expensive side..Who's the quote from? Link to comment Share on other sites More sharing options...
JGP Donating Members 309 Member For: 14y 5m 26d Gender: Male Posted 12/01/12 04:08 AM Share Posted 12/01/12 04:08 AM (edited) as above comments, injectors seem expensive? dekka 60s are about 350+- a set of six brand new(non installed)some performance sites list package prices, you can always compare with those to begin with and ask other reputable shops Edited 12/01/12 04:08 AM by JGP Link to comment Share on other sites More sharing options...
gsd112 Donating Members 604 Member For: 14y 5m 18d Gender: Male Location: Penrith Posted 12/01/12 04:10 AM Share Posted 12/01/12 04:10 AM (edited) My injectors were like $80 to fit, but maybe hes doing something else as well.Sorry missed the BA bit. Edited 12/01/12 04:12 AM by gsd112 Link to comment Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 17y 8m 28d Gender: Male Location: Melbourne Posted 12/01/12 04:11 AM Share Posted 12/01/12 04:11 AM Parts seems alright but labour seems steep, your spending that much you wouldn't expect to pay the off the street walkin price. See if you can work something out with them. Link to comment Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 17y 8m 28d Gender: Male Location: Melbourne Posted 12/01/12 04:14 AM Share Posted 12/01/12 04:14 AM People have got too 300rwkws for like 3.5k Link to comment Share on other sites More sharing options...
freeze_dk I am dissatisfied with my current employment situation Donating Members 8,610 Member For: 18y 4m 26d Gender: Male Posted 12/01/12 04:18 AM Share Posted 12/01/12 04:18 AM Half of those mods would see 280 Link to comment Share on other sites More sharing options...
