Ute Chucks A Traction Control Wobbly
tasvalowna
  • Member For: 13y 8m 12d
It is an FG , and its unlikely it was a wheelspin issue as I am carrying half a ton on it all the time. The road was bone dry BUT there are some of them little reflector bumpy jiggers in the middle of the road that I may have hit .Surely this couldnt be enough to upset things , could it?
  • Member For: 16y 2m 10d
Highly possible as it drops off the marker reflector at that speed, on a corner with load. Wheel speed might change slightly. Only minor though. My sedan on cruise control at that speed cuts out when it hits even minor bumps and the TC light flashes, took awhile to work that one out untill I watched it on the same patch of road.
Edited by Barra
  • 3 weeks later...
I might have solved my issue . the other day I drove to work and could get the episode to happen on any left hand bend , at will .
Then I checked the tyre pressures and the rhs was on 25 psi , I put 40 back in it and it hasnt played up again .
So im hoping this was my error and not a ford problem , so heres hoping it stays fixed .
Ben
