Not Enough Fuel Or Not Enough Spark? Or? Arrhh Help!
JNDXRT
  • I see a red door and I want to paint it black
  • Member For: 15y 3m 21d
1 - get rid of the generic tune and xcal1
2 - new coils
3 - gap the plugs to suit your boost
4 - you will need new valve springs if you want to tune it.
  • UNDERCOAT CRUISER!!!
  • Member For: 16y 29d
  • Member For: 14y 28d
I know a couple of people that have had a similar problem due to a loose fuel line on the intank Walbro. Especially if it's the one with the big intake because the pressure relief is turned up. The rubber hose with hose clips is not as good as the original and it can come loose or even split the hose. A friend replaced all his coils and plugs before finding this out.
If checking it make sure the tank is low on fuel if it's anything like the BF.
With the valve springs, if you boost hard and then come to a complete stop and it won't idle for a few seconds then there's a good chance that's a problem.
Cheers
Chris
Edited by riptide
  • Member For: 13y 3m 26d
cheers guys, yeah already had that problem with the pump ahah
umm yeah well see I just bought genuine ford coils wack them in soon and see what happens, atm im running like 80kms of juice and 91 octance on the 11psi flash tune and I just got wheel spin boosting into 2nd? wtf is happening! I say I <3 Bananas this tune off and get a vcm yes??
