FPV6T UNDERCOAT CRUISER!!! Donating Members 1,655 Member For: 16y 5m 19d Gender: Male Location: brisbane Posted 29/01/12 06:14 AM Share Posted 29/01/12 06:14 AM :stupid2: Link to comment https://www.fordxr6turbo.com/forum/topic/78716-not-enough-fuel-or-not-enough-spark-or-arrhh-help/page/2/#findComment-1187554 Share on other sites More sharing options...
JNDXRT Member 29 Member For: 13y 8m 16d Gender: Male Location: SA Posted 29/01/12 06:18 AM Author Share Posted 29/01/12 06:18 AM yeah its weird, today running the flash tune, fine no miss fire sound nothing ran smooth and boosted hard but then another day it will run like sh*t! so confused!yeah I guess chuck it on a dyno and have it testest check it all out to diognose the problem!can I get a tune straight to the ecu?? Link to comment https://www.fordxr6turbo.com/forum/topic/78716-not-enough-fuel-or-not-enough-spark-or-arrhh-help/page/2/#findComment-1187556 Share on other sites More sharing options...
JNDXRT Member 29 Member For: 13y 8m 16d Gender: Male Location: SA Posted 29/01/12 06:19 AM Author Share Posted 29/01/12 06:19 AM yeah giving it a squirt in high rev range then mate feels like the car is an earthquake and has stalled before... valve spring issue ahh sh*t.. Link to comment https://www.fordxr6turbo.com/forum/topic/78716-not-enough-fuel-or-not-enough-spark-or-arrhh-help/page/2/#findComment-1187557 Share on other sites More sharing options...
FPV6T UNDERCOAT CRUISER!!! Donating Members 1,655 Member For: 16y 5m 19d Gender: Male Location: brisbane Posted 29/01/12 06:20 AM Share Posted 29/01/12 06:20 AM yep, VCM tune. Link to comment https://www.fordxr6turbo.com/forum/topic/78716-not-enough-fuel-or-not-enough-spark-or-arrhh-help/page/2/#findComment-1187560 Share on other sites More sharing options...
MiKa Donating Members 4,243 Member For: 18y 10m 15d Gender: Male Location: Melbourne, VIC Posted 29/01/12 06:36 AM Share Posted 29/01/12 06:36 AM Could it be pinging? that brrrrrr sound doesn't sound good mate.. I wouldn't be giving it any till I got it on a dyno and looked at.. Esp when it isn't happening with the std tune is flashed in, means the 11psi tune isn't right.. Are your spark plugs gapped to .8mm?Generic tunees aren't any good as all cars are different and react different to the same mods done... basically your mods on my car would require a different tune to run right..Xcal 1's as the others have said are worthless now, you could buy a xcal 3 for around $700 and get your ecu tuned, or VCM or Sniper to get the ecu tuned, not sure how much that costs though.. Link to comment https://www.fordxr6turbo.com/forum/topic/78716-not-enough-fuel-or-not-enough-spark-or-arrhh-help/page/2/#findComment-1187577 Share on other sites More sharing options...
JNDXRT Member 29 Member For: 13y 8m 16d Gender: Male Location: SA Posted 29/01/12 06:41 AM Author Share Posted 29/01/12 06:41 AM cheers heaps guys ill deffs get it down for a dyno test and then a vcm tune but yeah heres a list of what I have read on forums and heard that my issue could be...-boost solenoid clean ( I did it and wow what a difference)-coils packs ( did not show up with an error code on a diognostics scan tool) (boostworx in SA say they dont show up??)-fuel filter and fuel pump (done both, fresh filter and walbro intank gss340 pump)-sticky wastegate and throttle body cleanout (lubes and cleand both)- MAP sensor and oxygen sensors (scan tool again there fine but did replace coolant temp sensor)- boost lines to the turbo compressor to the boost solenoid to the wastgate actuator spit? (check all are fine)- blocked cat? ( there is some heat discolouration and some people think it sounds blockd but others dont?)- fuel injectors ( not coping with 11psi? or just old or blocked? (full tank of bp 100 octane and injector cleaner)- spark plugs and gapping (done)and ive heard rubish about disconect ecu battery etc etc and over boost, factory ecu cut out, traction controll...and now valve spring issues..mind you my car now has 150,000kms could any of these things mensiond just be old and this happens? Link to comment https://www.fordxr6turbo.com/forum/topic/78716-not-enough-fuel-or-not-enough-spark-or-arrhh-help/page/2/#findComment-1187582 Share on other sites More sharing options...
JNDXRT Member 29 Member For: 13y 8m 16d Gender: Male Location: SA Posted 29/01/12 06:43 AM Author Share Posted 29/01/12 06:43 AM its not pinging, its more of a missfire mate:) if it was pinging illd be getting rid of it asap ! but yeah xcal 1 ima get rid of and just get a straight tune to my ecu having 150,000kms I dont wanna run high boost Link to comment https://www.fordxr6turbo.com/forum/topic/78716-not-enough-fuel-or-not-enough-spark-or-arrhh-help/page/2/#findComment-1187583 Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 7m 14d Gender: Male Location: SE Melbourne Posted 29/01/12 06:45 AM Share Posted 29/01/12 06:45 AM Id say your plugs are incorrectly gapped and yeah coils do t throw codes, you just gota replace them. Link to comment https://www.fordxr6turbo.com/forum/topic/78716-not-enough-fuel-or-not-enough-spark-or-arrhh-help/page/2/#findComment-1187586 Share on other sites More sharing options...
MiKa Donating Members 4,243 Member For: 18y 10m 15d Gender: Male Location: Melbourne, VIC Posted 29/01/12 06:49 AM Share Posted 29/01/12 06:49 AM (edited) Id say it is tune related more so than anything mechanical, as you've sussed out most things that it could be..Maybe its leaning out? does it happen with a full tank of fuel? My walbro when near 1/2 a tank would surge, drop power as if traction control kicked it, ran rough for a while too.. Who fitted it? some places don't know how to fit these properly and with the right hoses too.. Edited 29/01/12 06:50 AM by MiKa Link to comment https://www.fordxr6turbo.com/forum/topic/78716-not-enough-fuel-or-not-enough-spark-or-arrhh-help/page/2/#findComment-1187587 Share on other sites More sharing options...
JNDXRT Member 29 Member For: 13y 8m 16d Gender: Male Location: SA Posted 29/01/12 06:58 AM Author Share Posted 29/01/12 06:58 AM my plugs where gapped to .75 or .7my walbro pump was fitted by a mechanic seemed like its fiited fine.. maybe its the AFRYeah the brr sounds kinda feels like traction and sounds like it too but more like a missfiretoday running 1/4 tank shes boosting fine? no clue whats going on! maybe I should just vcm tune it and yeah 150,000kms the car has done maybe it has original coils and they have sh*t themselfs? but yeah for sure chuck it on dyno asap for a test and diognose it 1 Link to comment https://www.fordxr6turbo.com/forum/topic/78716-not-enough-fuel-or-not-enough-spark-or-arrhh-help/page/2/#findComment-1187593 Share on other sites More sharing options...
