  • Member For: 17y 5m 3d
Twin 2.5 is enough for 11's and low 300rwkw, I run the Manta version (two cats) in mild steel. I have been told the Manta twin 3" is less prone to drone, but mine only gets to me if towing at 100km/h though or if in high gears up hills for extended periods. I very much enjoy the sound of it at light throttle 1500RPM cruising or when puttering around at carpark speed too, sounds good when up it a bit too, not sure on how it compares at WOT as I'm too busy pointing the car in the right direction. Need to have someone film me...
Advantage of less restrictive exhaust would be lower boost for given power, plenum helps here too though I believe. I run 15PSI from 3k rpm to 6. That's down to the tune though of course.
Have heard xforce flow "ok" but can be difficult to fit straight, but man they are cheaper! Worth looking at.
Don't bother getting only cat back if you want power mods, always get full zorst and get it tuned. Add cooler to that and injectors/pump :)
Edited by -SteveR-
  • Dropping a turd
  • Member For: 17y 6m
Twin 2.5 will make a lot more than low 300s. I made 340 with an average twin 2.5. I would say a good one would go close to high 300,s 380 - 400. Manta twin 3 inch is overkill unless you are going over 400 rwkw and I heard are difficult to fit. Maybe the OP only wants a bit of noise. Cant beat the redback. then maybe throw in a cat later.
Edited by arronm
  • Member For: 13y 7m 21d
I have found a twin 2 1/2 inch xforce cat back exhaust on ebay and just wondering if anyone knows how this sounds. I would of gone the xforce 4" dump into single 3.5 but is a bit pricey for me so if any one knows of something good I can get for $1500 would help :)
  • Member For: 13y 7m 2d
Rapid systems sells mild steel xforce full systems for less than $1500 bro
  • Thooperrrrrrr
  • Member For: 13y 9m 25d
I think he means how much are you looking at in general from the car? 300/350/400kw etc as that will determine which setup you should go for
  On 31/01/2012 at 9:57 AM, tim182 said:
ok ive checkout the xforce systems on rapid systems and im happy with the price next question twins or single?
Quiet or loud? If you're after quiet no matter what power the 3.5" single might be too much for you....but tuners generally say it flows better than the twin 2.5" so that's the one to go for performance wise..best give your local tuner a call, after all they will be the one working with it and may have the right answers (not to undermine anyone's answers here, but I wished I'd listened to Lee the first time around)
Edited by Boogtonic
