spinr33 Donating Members 964 Member For: 13y 9m 15d Posted 30/01/12 05:06 AM Share Posted 30/01/12 05:06 AM If you read everyone else's post the Earls ones leak !! you need to get one with Speedflow fittings I have one same as mscn one doesnt leak after 4 months. Link to comment https://www.fordxr6turbo.com/forum/topic/78699-turbo-might-be-dead/page/4/#findComment-1188054 Share on other sites More sharing options...
ratter Member 6,793 Member For: 19y 5d Gender: Male Location: @ my laptop Posted 30/01/12 05:44 AM Share Posted 30/01/12 05:44 AM Not all the earl's ones leak, we have seen leaks from the plastic coated/crimped fitting style hoses, we have also seen that style that do not leak. never seen any leaks with the earlier style and which they will go back to if requested Link to comment https://www.fordxr6turbo.com/forum/topic/78699-turbo-might-be-dead/page/4/#findComment-1188067 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 7m 5d Gender: Male Location: Perth Posted 30/01/12 06:01 AM Share Posted 30/01/12 06:01 AM (edited) One of ours with the crimped ends is doing a little dribble. And if you have the clear coating on the line near the turbo end and its not protected it will burn and turn black.I put a heat sleeve on.Poor photo but you get the idea. Edited 30/01/12 06:03 AM by arronm Link to comment https://www.fordxr6turbo.com/forum/topic/78699-turbo-might-be-dead/page/4/#findComment-1188072 Share on other sites More sharing options...
XR64LT Donating Members 678 Member For: 17y 4m 24d Gender: Male Location: sydney Posted 30/01/12 10:18 AM Author Share Posted 30/01/12 10:18 AM Ok so what would people be doing now if you in my situation. Everyone has different opinions on what the problem is and what caused the turbo to die. Do I do every possible check on the motor, hope for the best and re-fit new / 2nd hand turbo with braided turbo line, or should I pull the motor out clean / check that nothing was damaged in the process and while im at it rebuild with stronger rod/pistons.? Link to comment https://www.fordxr6turbo.com/forum/topic/78699-turbo-might-be-dead/page/4/#findComment-1188341 Share on other sites More sharing options...
ratter Member 6,793 Member For: 19y 5d Gender: Male Location: @ my laptop Posted 30/01/12 10:34 AM Share Posted 30/01/12 10:34 AM 1st thing to do is to get it checked properly first before spending any money, otherwise it may cost you more without a proper diagnosis. Link to comment https://www.fordxr6turbo.com/forum/topic/78699-turbo-might-be-dead/page/4/#findComment-1188360 Share on other sites More sharing options...
XR64LT Donating Members 678 Member For: 17y 4m 24d Gender: Male Location: sydney Posted 30/01/12 11:13 AM Author Share Posted 30/01/12 11:13 AM ok so that master gauge test would check all that, anything I need to look out for while testing? Link to comment https://www.fordxr6turbo.com/forum/topic/78699-turbo-might-be-dead/page/4/#findComment-1188406 Share on other sites More sharing options...
ratter Member 6,793 Member For: 19y 5d Gender: Male Location: @ my laptop Posted 30/01/12 11:51 PM Share Posted 30/01/12 11:51 PM do the test cold and if pressure appears good let the oil get up to temp by leaving it run and record what pressure it is when the oil is hot.If oil pressure is good then check flow at the turbo. If good then check the drain back hose is free. Link to comment https://www.fordxr6turbo.com/forum/topic/78699-turbo-might-be-dead/page/4/#findComment-1188591 Share on other sites More sharing options...
XR64LT Donating Members 678 Member For: 17y 4m 24d Gender: Male Location: sydney Posted 31/01/12 01:08 AM Author Share Posted 31/01/12 01:08 AM And if all this is ok, there shouldnt be a problem with the motor? Link to comment https://www.fordxr6turbo.com/forum/topic/78699-turbo-might-be-dead/page/4/#findComment-1188633 Share on other sites More sharing options...
ratter Member 6,793 Member For: 19y 5d Gender: Male Location: @ my laptop Posted 31/01/12 02:57 AM Share Posted 31/01/12 02:57 AM (edited) Oil pressure wise, you would assume so, but you need to find out why the oil light came on Edited 31/01/12 02:58 AM by ratter Link to comment https://www.fordxr6turbo.com/forum/topic/78699-turbo-might-be-dead/page/4/#findComment-1188667 Share on other sites More sharing options...
XR64LT Donating Members 678 Member For: 17y 4m 24d Gender: Male Location: sydney Posted 31/01/12 06:13 AM Author Share Posted 31/01/12 06:13 AM OK just pulled out the owners manual and read the oil pressure warning indicator, it will illuminate only if the oil pressure or oil level falls belows an acceptable level. Fingers crossed that everything is ok should be getting the test done sometime this week or saturday at the latest. Link to comment https://www.fordxr6turbo.com/forum/topic/78699-turbo-might-be-dead/page/4/#findComment-1188769 Share on other sites More sharing options...
