Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 18y 4d Gender: Male Location: Melbourne Posted 26/01/12 05:42 AM Share Posted 26/01/12 05:42 AM Thought this info might help people on their next trip to the EPA or better still help you get around them in the first place.Some Key points would be that ALL oil filters are in fact illegal, you can have a pod or a bigger intercooler but not both and also larger injectors are illegal.I think if you really put the effort in you could could get some decent power out of your car and still pass an EPA test without having to change anything. In other words yeah it's hard but not impossible.It's an interesting read anyway.EPA GUIDELINEShttp://epanote2.epa..../$FILE/1031.pdfEnvironmental Protection Regulations.http://www.austlii.e...eg/eper2003563/VIC ROADS REGULATIONShttp://www.vicroads.vic.gov.au/NR/rdonlyres/CC48FC10-4D57-4F04-82E1-3BD72EF88340/0/VSI8.pdf Link to comment https://www.fordxr6turbo.com/forum/topic/78675-taking-on-the-epa/ Share on other sites More sharing options...
Kosij Donating Members 2,045 Member For: 13y 9m 19d Gender: Male Posted 26/01/12 05:55 AM Share Posted 26/01/12 05:55 AM What a load of bull sh*t! Link to comment https://www.fordxr6turbo.com/forum/topic/78675-taking-on-the-epa/#findComment-1186094 Share on other sites More sharing options...
Henz Tampon inserted, Auto Acquired, next purchase a new handbag Donating Members 9,946 Member For: 17y 2m 10d Gender: Male Location: Vic Posted 26/01/12 05:56 AM Share Posted 26/01/12 05:56 AM My stock exhaust with centre muffler out, and it was fairly quiet, passed the noise test by .5db. Some helpful info. Link to comment https://www.fordxr6turbo.com/forum/topic/78675-taking-on-the-epa/#findComment-1186095 Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 18y 4d Gender: Male Location: Melbourne Posted 26/01/12 06:00 AM Author Share Posted 26/01/12 06:00 AM Was that after a tune?The only spot I could see where you might get stuck is injectors, will either need to get bigger ones approved or hopefully at least be able to use F6 ones on XR's. Link to comment https://www.fordxr6turbo.com/forum/topic/78675-taking-on-the-epa/#findComment-1186097 Share on other sites More sharing options...
dre Resident idiot. Donating Members 2,068 Member For: 14y 8m 9d Gender: Male Location: Melbourne Posted 26/01/12 06:06 AM Share Posted 26/01/12 06:06 AM It's getting so hard to modify cars these days. Will be going for the standard look next time. Link to comment https://www.fordxr6turbo.com/forum/topic/78675-taking-on-the-epa/#findComment-1186099 Share on other sites More sharing options...
Pazzo Donating Members 11,132 Member For: 14y 7m 8d Gender: Male Posted 26/01/12 06:21 AM Share Posted 26/01/12 06:21 AM On 26/01/2012 at 6:06 AM, dre said: It's getting so hard to modify cars these days. Will be going for the standard look next time.Not wrong Dre getting harder and harder. The cops know what to look for now, not as stupid as they once were. Link to comment https://www.fordxr6turbo.com/forum/topic/78675-taking-on-the-epa/#findComment-1186101 Share on other sites More sharing options...
Henz Tampon inserted, Auto Acquired, next purchase a new handbag Donating Members 9,946 Member For: 17y 2m 10d Gender: Male Location: Vic Posted 26/01/12 06:34 AM Share Posted 26/01/12 06:34 AM That was stock tune flashed back in, all stock piping but no bov, which they noted. Link to comment https://www.fordxr6turbo.com/forum/topic/78675-taking-on-the-epa/#findComment-1186107 Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 18y 4d Gender: Male Location: Melbourne Posted 26/01/12 07:18 AM Author Share Posted 26/01/12 07:18 AM Chucked up vic roads too, it's crazy the hoops you got to jump through just for a hobby.270 is the widest we are allowed on the back too, who the f*ck makes a 270 width tyre? Link to comment https://www.fordxr6turbo.com/forum/topic/78675-taking-on-the-epa/#findComment-1186127 Share on other sites More sharing options...
ebxmple Member 1,322 Member For: 17y 3m 29d Posted 26/01/12 07:42 AM Share Posted 26/01/12 07:42 AM How are testers going to know if you have bigger injectors? Especially if they are drilled factory items. If you have injectors and a tune,aslong as the smelly stuff coming out the back is within specs,they cant do anything yeah? As I have said before,somehow Nizpro have done whatever it takes to get their full kits to pass. Maybe without exhausts on the B series but pretty sure they pass with exhaust on FGs.. Bit of comfort for people thinking bout modding legally. Link to comment https://www.fordxr6turbo.com/forum/topic/78675-taking-on-the-epa/#findComment-1186131 Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 18y 4d Gender: Male Location: Melbourne Posted 26/01/12 07:50 AM Author Share Posted 26/01/12 07:50 AM They can pull them out and test them if they want. Drilled injectors would be a loophole I guess as they are still a factory unit, same thing hopefully with F6 ones.Nizpro kits can't/won't pass if they have a cooler and a pod as that rule is clear as day. Even if your exhaust passes emissions I doubt any high flow exhaust bigger then stock will pass a noise test.However with a bit of luck an FG with F6 injectors, high flowed stock air box with panel filter, high flow cat and big cooler should technically be ok and still make 300.. Link to comment https://www.fordxr6turbo.com/forum/topic/78675-taking-on-the-epa/#findComment-1186133 Share on other sites More sharing options...
