envyit Member 103 Member For: 16y 9m 11d Posted 21/01/12 06:51 AM Share Posted 21/01/12 06:51 AM Hi guys I have my car at my mechanics its got bugger all fuel pressure he tells me its the reg is there a upgrade for these? I really don't want to go another standard one as the standard one has failed me any suggestion would be much appreciated Thanks in advance Justin Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 5m 20d Gender: Male Location: @ my laptop Posted 21/01/12 06:53 AM Share Posted 21/01/12 06:53 AM there are none that are a direct replacement, the standard one's normally have a very low failure rate unless it gets debris in it Link to comment Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 4m 8d Gender: Male Location: OZ Posted 05/02/12 01:39 PM Share Posted 05/02/12 01:39 PM There are direct replacements available that are 'blueprinted' I.e tested for precise regulation. They also have a bigger diameter return which works well if you're using a big fuel pump such as a 044. Have a look at eurospec or 034motorsports overseas. I've used the 4.5 bar also....it's a good way to get more capacity out of 968's or GT500 EV14 injectors if you have a 044 with some reserve! Link to comment Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 15y 11m 25d Gender: Male Location: SE Melbourne Posted 05/02/12 11:37 PM Share Posted 05/02/12 11:37 PM There are direct replacements available that are 'blueprinted' I.e tested for precise regulation. They also have a bigger diameter return which works well if you're using a big fuel pump such as a 044. Have a look at eurospec or 034motorsports overseas. I've used the 4.5 bar also....it's a good way to get more capacity out of 968's or GT500 EV14 injectors if you have a 044 with some reserve!Hi mate, what is the most power you have seen made with 968's and 044?(assuming no other restrictions) Link to comment Share on other sites More sharing options...
