Azid Member 213 Member For: 13y 9m 15d Posted 20/01/12 11:24 AM Share Posted 20/01/12 11:24 AM Hey guysDoes anyone have a walk through or explain how to do a fibreglass boot set up. I know u make the basic shape out of timber but that's bout it do u wrap it in a material and apply the fibreglass putty to the material or what? I'm keen to give it a try Link to comment https://www.fordxr6turbo.com/forum/topic/78617-fibreglassing-sub-boxes/ Share on other sites More sharing options...
ms700 Moderating Team 10,170 Member For: 22y 5m 2d Gender: Male Location: Sydney Posted 20/01/12 08:04 PM Share Posted 20/01/12 08:04 PM Umm fibreglass isnt a putty as suchFibreglass is like a matt material, you then have to add resin to that material to make it set rigid. And you mix the resin with a hardener before the application to make it set properly. Add to much hardener and it will set before you are ready. Dont add enough hardener and it will take ages to go off. Oh yeah, you need to take into account how hot or cold it is too! Oh yeah, the resin can get to your head too, so make sure you are working in a well ventilated area.If you havent got any experience in it, Id suggest practicing on something not so ambitious as a sub box, as it will turn real messy, real quick. Cleaning resin up out of boot carpet is virtually impossible. Link to comment https://www.fordxr6turbo.com/forum/topic/78617-fibreglassing-sub-boxes/#findComment-1184031 Share on other sites More sharing options...
Dagabond Bored Member Administrator 35,722 Member For: 22y 7m 19d Gender: Male Location: Dé·jà vu Posted 20/01/12 11:36 PM Share Posted 20/01/12 11:36 PM Link to comment https://www.fordxr6turbo.com/forum/topic/78617-fibreglassing-sub-boxes/#findComment-1184069 Share on other sites More sharing options...
Gussa Donating Members 220 Member For: 14y 4m 29d Gender: Male Location: Gippsland Posted 21/01/12 12:25 AM Share Posted 21/01/12 12:25 AM Make sure you account for the correct box volume to suit the speaker. Very important. Link to comment https://www.fordxr6turbo.com/forum/topic/78617-fibreglassing-sub-boxes/#findComment-1184084 Share on other sites More sharing options...
ms700 Moderating Team 10,170 Member For: 22y 5m 2d Gender: Male Location: Sydney Posted 21/01/12 05:09 AM Share Posted 21/01/12 05:09 AM lol @ dagsshould read my posts before hitting "post"oh yeah Link to comment https://www.fordxr6turbo.com/forum/topic/78617-fibreglassing-sub-boxes/#findComment-1184179 Share on other sites More sharing options...
Azid Member 213 Member For: 13y 9m 15d Posted 21/01/12 11:47 AM Author Share Posted 21/01/12 11:47 AM So any info walkthroughs? Link to comment https://www.fordxr6turbo.com/forum/topic/78617-fibreglassing-sub-boxes/#findComment-1184298 Share on other sites More sharing options...
knoles Donating Members 390 Member For: 14y 3m 17d Gender: Male Location: Port Hedland Posted 22/01/12 04:14 AM Share Posted 22/01/12 04:14 AM I had the same idea about 2 years ago of making fully sick fibreglass sub boxes, I made a few. None of them I was ever happy with either the build quality or strength or something was always wrong. Ended up making a wooden box to perfect spec and was alot happier with it. I learnt everything off you tube, theres lots of vids on there. Link to comment https://www.fordxr6turbo.com/forum/topic/78617-fibreglassing-sub-boxes/#findComment-1184449 Share on other sites More sharing options...
1NSANE Donating Members 279 Member For: 15y 1m 24d Gender: Male Location: South West Melbourne Posted 22/01/12 08:31 AM Share Posted 22/01/12 08:31 AM You will either have to use your boot as the mould or make another mould to use. I used my boot when I did mine but make sure you cover your boot with masking tape and I used aluminium foil as a release agent. Once I got the shape with a couple of layers of fibreglass I took it out and finished it. Just be aware of your boots opening area so you can get it in and out and have some wood bracing inside. I was an amateur and I only did this once but it turned out well. Hope I helped. Good luck.Ben Link to comment https://www.fordxr6turbo.com/forum/topic/78617-fibreglassing-sub-boxes/#findComment-1184556 Share on other sites More sharing options...
Azid Member 213 Member For: 13y 9m 15d Posted 22/01/12 03:44 PM Author Share Posted 22/01/12 03:44 PM So correct me if I'm wrong from what I've read. You build your shape. Use material to help get shape. Then you cover it in a resin and let it dryThen u layer it with mat. Sand it back and keep doing layersThen do u have to use a body filler for some reason. Sand it back then u paint it? Link to comment https://www.fordxr6turbo.com/forum/topic/78617-fibreglassing-sub-boxes/#findComment-1184657 Share on other sites More sharing options...
XAH03 Member 597 Member For: 17y 8m 4d Gender: Male Location: Cairns QLD Posted 22/01/12 11:47 PM Share Posted 22/01/12 11:47 PM Make mould. Make sure you have a releasing type material so the fiberglass mould will pull away once it dries (I use celo tape at work) sometimes if we are making a new mould we also coat the mould in a thin layer of polish so it's easier to pull away from.Cut your strips of matting up for your hard to reach areas and this makes it easier to get it all good and done properly.On your bigger areas you can obviously use larger sections of glass mat. Also make sure you have enough glass for the job, you don't want to get half way through the job and run out.Get a paint brush, you may want a smaller one for small and tight areas and also a larger for large sections.Make up your resin and catalyst mix. We use a 2% catalyst to resin ratio. Again make sure you have enough for the job. Make sure the mix ratio is right. Different products may have a different ratio, should say on the labels anyway.Brush the resin mix onto the mould you have made up. Then once you have a layer of resin down lay your mat over the top and brush more resin onto the mat. Once that layer of mat is done repeat laying more mat and resin down until you have your desired thickness. After each layer and before you start the next layer make sure there are no dry parts of mat because then you'll get air bubbles and it will be brittle and easier to crack. When I repair glass body kits depending on where it is I will usually lay 4-6 layers down.Once this is all done grab yourself a beer sit back and watch your fiberglassing excellence dry.After its dry and your happy with it sand it back a bit so the bog/ body filler will stick to the job, sand it up sand till it's smooth then paint.Now grab another beer and listen to the fully sick doof doof. Link to comment https://www.fordxr6turbo.com/forum/topic/78617-fibreglassing-sub-boxes/#findComment-1184704 Share on other sites More sharing options...
