04RSD Member 78 Member For: 18y 9m 2d Posted 19/01/12 09:20 PM Share Posted 19/01/12 09:20 PM hey guys I hust got myself a written off 5 speed ba xr6 for a donor vehicle.its been sitting with a flat battery for a good 8 months, I put a new battery in but no luck.my radio is showing CODE with ign on ( as soon as you turn ign on it should talk to bcm and power up )there is no crank, a few of the dash lights drop out as normal on crank but the little hand with the key and the red (!) flash up,im guessing dead bcm but im just guessing.I have a snap-on ETHOS scan tool but its pretty much useless for anything bigger than resetting seatbelt and airbag codes.any help would be great.I want to have a quick drive to make sure sure everything works ok Link to comment https://www.fordxr6turbo.com/forum/topic/78607-where-is-the-bcm-an-a-ba/ Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 22y 2m 7d Gender: Male Location: Victoria Posted 19/01/12 09:52 PM Share Posted 19/01/12 09:52 PM PCM or BEM?PCM is in the engine bay.BEM is under the ICC.If they're not trained for the same car they won't get along. Link to comment https://www.fordxr6turbo.com/forum/topic/78607-where-is-the-bcm-an-a-ba/#findComment-1183497 Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 7m 11d Gender: Male Location: SE Melbourne Posted 19/01/12 10:54 PM Share Posted 19/01/12 10:54 PM (edited) BEM is part of the ICC. you will need to get it reset by ford if you want it to talk to another car. check all connectors at the PCM and BEM. Disconnect and connect everything just to make sure its all good.Make sure you get it working on that car before pulling stuff out. Otherwise you will spend a lot of time chasing your tail. Edited 19/01/12 10:57 PM by Paulie2256 Link to comment https://www.fordxr6turbo.com/forum/topic/78607-where-is-the-bcm-an-a-ba/#findComment-1183503 Share on other sites More sharing options...
04RSD Member 78 Member For: 18y 9m 2d Posted 20/01/12 12:11 AM Author Share Posted 20/01/12 12:11 AM the icc hasnt been changed out, the guy said he turned the car off after it hit the pole it got towed away and he never tried starting it since then.im trying to make sure it all works before I pull it out and fit it into my ED Link to comment https://www.fordxr6turbo.com/forum/topic/78607-where-is-the-bcm-an-a-ba/#findComment-1183546 Share on other sites More sharing options...
matt036 Donating Members 280 Member For: 15y 5m 25d Gender: Male Posted 20/01/12 03:14 AM Share Posted 20/01/12 03:14 AM Ive heard (working in a ford dealership) that if they sit for a long enough period of time without a battery the bem resets itself and will show code on the icc, which means taking it to a ford dealership and having the keys and module reset or else it will never work. Link to comment https://www.fordxr6turbo.com/forum/topic/78607-where-is-the-bcm-an-a-ba/#findComment-1183634 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 10d Gender: Male Location: Perth Posted 20/01/12 03:28 AM Share Posted 20/01/12 03:28 AM ^ nope. Pcm cant forget who it is.Will be an issue related too the crash Link to comment https://www.fordxr6turbo.com/forum/topic/78607-where-is-the-bcm-an-a-ba/#findComment-1183639 Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 21y 2m 8d Gender: Male Location: Brisbane Posted 20/01/12 03:34 AM Share Posted 20/01/12 03:34 AM (edited) Fuel cut switch? ...scratch that, just re-read the "no crank" bit Edited 20/01/12 03:34 AM by tab Link to comment https://www.fordxr6turbo.com/forum/topic/78607-where-is-the-bcm-an-a-ba/#findComment-1183642 Share on other sites More sharing options...
matt036 Donating Members 280 Member For: 15y 5m 25d Gender: Male Posted 20/01/12 03:36 AM Share Posted 20/01/12 03:36 AM (edited) But its not the pcm that has anything to do with memory retention, its bem module (underneath the icc) that retains the cars code information and when its right (as in keys and everything is coded properly) it tells the pcm to start. Not the other way around. If its lost code then that would explain why it won't start. Edited 20/01/12 03:39 AM by matt036 Link to comment https://www.fordxr6turbo.com/forum/topic/78607-where-is-the-bcm-an-a-ba/#findComment-1183643 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 10d Gender: Male Location: Perth Posted 20/01/12 03:47 AM Share Posted 20/01/12 03:47 AM Yes, but the car has had a pretty major hit in the side. My money is the ICC has been dislodged and this is causing the code issue. The security functions are written in flash memory into the BEM, the settings cant be lost due too a flat battery.Look for obvious damage and work backwards from there.OP are you 110% sure you've been given the correct keys for the car? no damage too the ignition barrel receiver for the security system? No damage too the PCM connectors? Link to comment https://www.fordxr6turbo.com/forum/topic/78607-where-is-the-bcm-an-a-ba/#findComment-1183652 Share on other sites More sharing options...
Azid Member 213 Member For: 13y 9m 14d Posted 20/01/12 05:30 AM Share Posted 20/01/12 05:30 AM Separate question but what are you doing to your ED with this? Link to comment https://www.fordxr6turbo.com/forum/topic/78607-where-is-the-bcm-an-a-ba/#findComment-1183694 Share on other sites More sharing options...
