Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 26d Gender: Male Location: Perth Posted 19/01/12 02:50 AM Share Posted 19/01/12 02:50 AM I have used numerous mp3 players, A 3gs, A nokia N8/N95 and Now my SG2 and they all whineCiaran, you realise your N8 has an Fm transmitter dont you? Save your $'s set that up and tune the ICC too it Link to comment https://www.fordxr6turbo.com/forum/topic/78581-adding-aux-cable-to-premium-sound-a-guide/page/3/#findComment-1183032 Share on other sites More sharing options...
Ciaran Thooperrrrrrr Donating Members 2,768 Member For: 13y 10m 17d Gender: Male Location: NOR, Western Australia Posted 19/01/12 02:50 AM Share Posted 19/01/12 02:50 AM (edited) I think I'd be happy with music I like though instead of being completely unable to play them (unless I make plenty of 17 track CD's which is annoying as hell)EDIT: I actually forgot about that FM transmitter.I've bought it now :( All good, also have an MP3 player that I'll use with it Edited 19/01/12 03:02 AM by Ciaran Link to comment https://www.fordxr6turbo.com/forum/topic/78581-adding-aux-cable-to-premium-sound-a-guide/page/3/#findComment-1183033 Share on other sites More sharing options...
hgreen Member 8 Member For: 13y 11m 22d Posted 19/01/12 08:24 AM Share Posted 19/01/12 08:24 AM Just installed the boosted aux kit from ASL Automedia in my BA. Works a charm. Volume is the exact same as the CD volume. And there is also adjustable gain on the little amp to match it if needed. Good sound quality. Pretty close to CD quality except loses out some bass just a tiny bit. But Could correct that with the audio settings on the ICC or maybe the EQ on my ipod. Link to comment https://www.fordxr6turbo.com/forum/topic/78581-adding-aux-cable-to-premium-sound-a-guide/page/3/#findComment-1183222 Share on other sites More sharing options...
1600dave Donating Members 872 Member For: 14y 4m 10d Posted 19/01/12 09:21 AM Share Posted 19/01/12 09:21 AM I had the ASL kit too, ended up selling it, the noise was terrible. Some cars are ok, others are just shocking. Link to comment https://www.fordxr6turbo.com/forum/topic/78581-adding-aux-cable-to-premium-sound-a-guide/page/3/#findComment-1183258 Share on other sites More sharing options...
Ciaran Thooperrrrrrr Donating Members 2,768 Member For: 13y 10m 17d Gender: Male Location: NOR, Western Australia Posted 25/01/12 11:11 PM Share Posted 25/01/12 11:11 PM (edited) Just tried installing my booster kit then, but how the hell do you feed the remaining cables through to the tissue box? Can't seem to get it through the gaps and not sure if there is an easier way without removing the ICCAlso, the double sided tape they gave me was sheet. Even after cleaning the spot it was going to stick on, placed it there, held it for about 20s then it fell straight off.Ended up using a cable tie to one of the beams behind the ICC Edited 25/01/12 11:12 PM by Ciaran Link to comment https://www.fordxr6turbo.com/forum/topic/78581-adding-aux-cable-to-premium-sound-a-guide/page/3/#findComment-1186020 Share on other sites More sharing options...
quadie Donating Members 720 Member For: 19y 6m 15d Gender: Male Location: Muswellbrook,NSW Posted 25/01/12 11:26 PM Share Posted 25/01/12 11:26 PM you only need to remove the tissus hoder(hint: a metal coathanger or a bit of filler rod , fencing wire is your friend)feed it through tape up the the connector to it and pull it back thoughmines cable tied also Link to comment https://www.fordxr6turbo.com/forum/topic/78581-adding-aux-cable-to-premium-sound-a-guide/page/3/#findComment-1186022 Share on other sites More sharing options...
1600dave Donating Members 872 Member For: 14y 4m 10d Posted 25/01/12 11:27 PM Share Posted 25/01/12 11:27 PM I just removed the tissue box section and used a torch so I could see easier and fed it through. There isn't much room but its not too hard as the cable are relatively stiff.I used cable ties for mine too. Hows your sound quality? Link to comment https://www.fordxr6turbo.com/forum/topic/78581-adding-aux-cable-to-premium-sound-a-guide/page/3/#findComment-1186023 Share on other sites More sharing options...
Ciaran Thooperrrrrrr Donating Members 2,768 Member For: 13y 10m 17d Gender: Male Location: NOR, Western Australia Posted 25/01/12 11:54 PM Share Posted 25/01/12 11:54 PM Cheers for the tips.Haven't tried the sound out yet, probably should have before I wired it all through haha.Going to use the coathanger trick now (or once the daughter settles down) so I can put my interior back together then will let you know. Link to comment https://www.fordxr6turbo.com/forum/topic/78581-adding-aux-cable-to-premium-sound-a-guide/page/3/#findComment-1186029 Share on other sites More sharing options...
Ciaran Thooperrrrrrr Donating Members 2,768 Member For: 13y 10m 17d Gender: Male Location: NOR, Western Australia Posted 26/01/12 01:52 AM Share Posted 26/01/12 01:52 AM Coat hanger worked a treat and the sound seems pretty decent.At first I just turned the ignition on but didnt start the car, and it sounded like there was a lot of interference (this was before anything was playing) but once the music started it was pretty clear. Link to comment https://www.fordxr6turbo.com/forum/topic/78581-adding-aux-cable-to-premium-sound-a-guide/page/3/#findComment-1186052 Share on other sites More sharing options...
quadie Donating Members 720 Member For: 19y 6m 15d Gender: Male Location: Muswellbrook,NSW Posted 26/01/12 06:29 AM Share Posted 26/01/12 06:29 AM good to hear.well done Link to comment https://www.fordxr6turbo.com/forum/topic/78581-adding-aux-cable-to-premium-sound-a-guide/page/3/#findComment-1186106 Share on other sites More sharing options...
