bigblu222 New Member 13 Member For: 16y 2m 22d Gender: Male Location: Kapiti Posted 18/01/12 06:50 AM Share Posted 18/01/12 06:50 AM Club dyno day.Car is stock, except for BMC filter centre muffler removed.Other cars on the day dyno'd as expected.Previous car (BA XR6T dyno'd on same machine spun 204rwkW, as expected for mods done to car).So........., do I have a goodie, or is the dyno optimistic?? Link to comment https://www.fordxr6turbo.com/forum/topic/78572-dyno-results/ Share on other sites More sharing options...
CBXRT Banned 643 Member For: 14y 5m 18d Gender: Male Posted 18/01/12 07:07 AM Share Posted 18/01/12 07:07 AM (edited) Did you buy the car new? If not it may have already been tweaked in tuning?204rwkw for BAT is average at best.......so couldnt have had too many mods done to get below a stock version!!!All I can say is that the dyno sounds a bit off (yours high, the BAT low if it had mods), but who knows mate, you could have bought one out of the box.Cheers. Edited 18/01/12 07:08 AM by CBXRT Link to comment https://www.fordxr6turbo.com/forum/topic/78572-dyno-results/#findComment-1182614 Share on other sites More sharing options...
bigblu222 New Member 13 Member For: 16y 2m 22d Gender: Male Location: Kapiti Posted 18/01/12 07:19 AM Author Share Posted 18/01/12 07:19 AM Car was bought Jan 2011 with 2 previous owners (neither of whom sounded like rev heads) & 67000 kms on the clock.BA was lightly modded (F6 lower intake, John Bowe cat back). Link to comment https://www.fordxr6turbo.com/forum/topic/78572-dyno-results/#findComment-1182624 Share on other sites More sharing options...
MiKa Donating Members 4,243 Member For: 18y 8m 20d Gender: Male Location: Melbourne, VIC Posted 18/01/12 07:19 AM Share Posted 18/01/12 07:19 AM As others will say, take it down the strip and see the mph...What mods did the BAT have? 204rwkw is high if it was fairly stock (no tune) Link to comment https://www.fordxr6turbo.com/forum/topic/78572-dyno-results/#findComment-1182625 Share on other sites More sharing options...
bigblu222 New Member 13 Member For: 16y 2m 22d Gender: Male Location: Kapiti Posted 18/01/12 07:24 AM Author Share Posted 18/01/12 07:24 AM BA was lightly modded (F6 lower intake, John Bowe cat back). Closest strip is a part timer (airport runway) & 2 hours away, so haven't yet had a run.Waiting for the permanent one to be built, then will see about a street meet or test & tune. Link to comment https://www.fordxr6turbo.com/forum/topic/78572-dyno-results/#findComment-1182628 Share on other sites More sharing options...
CBXRT Banned 643 Member For: 14y 5m 18d Gender: Male Posted 18/01/12 08:08 AM Share Posted 18/01/12 08:08 AM On 18/01/2012 at 7:19 AM, MiKa said: 204rwkw is high if it was fairly stock (no tune)No its not. On 18/01/2012 at 7:24 AM, bigblu222 said: BA was lightly modded (F6 lower intake, John Bowe cat back). John Bowe exhaust most likely did nothing (or hindered as many aftermarket do compared to stock....unless tuned for it) and intake would be lucky to give 2 or 3 rwkw.So the 204 firgure would be accurate so it means your Typhoon is especially high for its model for some reason! Link to comment https://www.fordxr6turbo.com/forum/topic/78572-dyno-results/#findComment-1182648 Share on other sites More sharing options...
bluprinturbo Donating Members 605 Member For: 17y Gender: Male Location: brisbane Posted 18/01/12 11:20 AM Share Posted 18/01/12 11:20 AM (edited) So your saying CBXRT THAT 204 RWKWS for a BA TURBO is average at best? We are talking a T and not a PHOON yes? If you are talking about a T than, as in your other posts in various other threads, you have your hand firmly planted on it. Edited 18/01/12 11:34 AM by bluprinturbo Link to comment https://www.fordxr6turbo.com/forum/topic/78572-dyno-results/#findComment-1182810 Share on other sites More sharing options...
Brods Member 433 Member For: 14y 9m 12d Gender: Male Posted 18/01/12 11:39 AM Share Posted 18/01/12 11:39 AM Stock BA T would more likely be around 190 rwkw maybe less Link to comment https://www.fordxr6turbo.com/forum/topic/78572-dyno-results/#findComment-1182814 Share on other sites More sharing options...
Worm A much better forum Silver Donating Members 3,808 Member For: 16y 9m 18d Gender: Male Location: Victoria Posted 18/01/12 11:40 AM Share Posted 18/01/12 11:40 AM T's can be anywhere from 160rwkw to 210rwkw...Average is about 190-200rwkw...259rwkw is bullsh*t for a stock T and a stock phoon... Some tune only BA's don't make 250...Where is boost reading? I reckon it's running 10psi not 7... Link to comment https://www.fordxr6turbo.com/forum/topic/78572-dyno-results/#findComment-1182815 Share on other sites More sharing options...
CBXRT Banned 643 Member For: 14y 5m 18d Gender: Male Posted 18/01/12 11:42 AM Share Posted 18/01/12 11:42 AM (edited) On 18/01/2012 at 11:20 AM, bluprinturbo said: So your saying CBXRT THAT 204 RWKWS for a BA TURBO is average at best? We are talking a T and not a PHOON yes? If you are talking about a T than, as in your other posts in various other threads, you have your hand firmly planted on it.A BA turbo made 240-255kw at fly stock - they underquoted to ensure the XR8 had a higher figure.With 15-20% power loss to rwkw its 37-50 less = easily 195ish-210ish depending on the particular car. Heaps of guys have dynoed above 200 with a stock T, so maybe you need to put your hand on it to get back into reality........or maybe you cant find it. lolA Phoon can make above 225 - which makes sense considering its flywheel figure. Edited 18/01/12 11:49 AM by CBXRT Link to comment https://www.fordxr6turbo.com/forum/topic/78572-dyno-results/#findComment-1182816 Share on other sites More sharing options...
