CBXRT Banned 643 Member For: 14y 6m 18d Gender: Male Posted 18/01/12 04:41 AM Share Posted 18/01/12 04:41 AM On 18/01/2012 at 2:35 AM, PookeyMaster said: Was the Extended Warranty from the Dealer or from Ford Motor Company of Australia?If it was from the Dealer, try often require all services to be done at that particular dealer in which case you may be out of luck.IGood pick-up mate. That could be the issue, and why the Dealer is refusing to honour the warranty.Extended warranties/Dealer warranties have always been chameleons........ 1 Link to comment https://www.fordxr6turbo.com/forum/topic/78562-bfxr6-blown-engine-turbo-ford-extended-warranty-claim-refused/page/2/#findComment-1182505 Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 22y 2m 11d Gender: Male Posted 18/01/12 05:16 AM Share Posted 18/01/12 05:16 AM If the above suggestions fail then as a last resort I would ask that Ford dealer to give you the quote to repair your vehicle. In there should be a list of what is wrong with the car. If it is not get them to write down what the problem is.Like when people say blown this and blown that, it really does not mean much. Cant see how the turbo took out the engine.Then get the car back home and find a trustworthy mobile mechanic who can help work out if their diagnosis is accurate.With the turbo for starters just take off the inlet and have a look at the compressor wheel, see if its in one piece and if the wheel hits the side of the compressor housing. All of 15 min work.With engine, see if can start up and if its making noises. Your mechanic can do things like a compression test, leak down test to work out what is wrong.Get the car fixed privately as chances are the Ford dealer price is overpriced in the first place then sue the dealer later in the small claims court. Provided you have your service receipts then you might be OK. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/78562-bfxr6-blown-engine-turbo-ford-extended-warranty-claim-refused/page/2/#findComment-1182529 Share on other sites More sharing options...
Rapidyellowxr6tute Donating Members 123 Member For: 13y 4m 29d Gender: Male Location: Yarra Valley, Victoria Posted 18/01/12 07:55 AM Share Posted 18/01/12 07:55 AM Hi Karen, very sorry to hear of your unfortunate situation. I agree in regards to how a blown turbo could cause the engine to let go as well????? I would have an independant party check over the car and list what is specifically wrong and find out exactly what caused the engine/turbo to fail if that is in fact the case. As I'm not sure where you are located, I would quite happily come and have a look over the car for you (if you were relatively local) with a close friend who is an excellent and very thorough mechanic and certainly knows his way around a vehicle. Maybe one of our fellow knowledgable forum members is local to you and could spare an hour or so of thier time to have a look, at least then you could have some peace of mind knowing exactly what is required to get your pride and joy back on the road.....it quite possibly may be not as bad as first thought?I wish you all the best and hope you can get some resolve with this unfortunate situation.Kind regards, Paul. Link to comment https://www.fordxr6turbo.com/forum/topic/78562-bfxr6-blown-engine-turbo-ford-extended-warranty-claim-refused/page/2/#findComment-1182636 Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 21y 1m 16d Gender: Male Location: Brisbane Posted 18/01/12 09:39 AM Share Posted 18/01/12 09:39 AM Offered you $3000? Sounds like an absolutely lovely bunch of fckn parasites.The other thing is too, if it was serviced at a Ford dealer that should be recorded on their system and fairly easily traceable, as it should for any decent mechanic too I guess.You mentioned VCAT so I assume you're in Victoria, should certainly be able to find some willing participants on here to do all that they can to help (as kindly offered above).Best of luck with it and hopefully things are starting to look-up for you. Link to comment https://www.fordxr6turbo.com/forum/topic/78562-bfxr6-blown-engine-turbo-ford-extended-warranty-claim-refused/page/2/#findComment-1182748 Share on other sites More sharing options...
Impellor Member 835 Member For: 14y 10m 21d Gender: Not Telling Posted 18/01/12 10:05 AM Share Posted 18/01/12 10:05 AM Karen, I am saddened to hear of your predicament. If you have no luck with your warranty claim, you may consider this if you are fortunate enough to get some support from a mechanic. My proposal is that you find someone who is prepared to get the car to their workshop.Then fix the car at their cost, however they would retain the car and sell it on your behalf. This way it ensures the the repairer is paid and that you recieve a substanially greater amount for the car. I would imagine a BFII with 70000kms and a new engine should attract 17k buyers. Hoping things work out for. Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/78562-bfxr6-blown-engine-turbo-ford-extended-warranty-claim-refused/page/2/#findComment-1182768 Share on other sites More sharing options...
45T-XR Donating Members 417 Member For: 18y 3m 4d Gender: Male Location: Gladstone, Queensland Posted 19/01/12 09:16 AM Share Posted 19/01/12 09:16 AM Hi Karen, as fellow members we are very sorry for the situation you are in at present.All the above suggestions are great and worth consideration. If you could name and shame the dealer and also give us your location we might be able to help out a bit more.If you in my area Im sure I would be able to help you out with labour for free 2 Link to comment https://www.fordxr6turbo.com/forum/topic/78562-bfxr6-blown-engine-turbo-ford-extended-warranty-claim-refused/page/2/#findComment-1183254 Share on other sites More sharing options...
WILDB Donating Members 28 Member For: 14y 8m 24d Gender: Male Location: Sunshine Coast Posted 23/01/12 08:33 PM Share Posted 23/01/12 08:33 PM (edited) Hi Karen,I'm very sorry to hear of your situation.As others have asked what sort of warranty was it? Myford, Blue Care etc? These are all underwritten by third parties (not Ford) and they are the ones who make the decisions as to yes or no - knowing which one may help with some sort of explanation as to why repair authority has been denied.Has the vehicle got any modifications at all? I.e LPG or something?How many km were on the vehicle at time of failure?Do you have a complete service history? I.e services done by the book based on distance or time? No late services? Edited 23/01/12 08:34 PM by WILDB Link to comment https://www.fordxr6turbo.com/forum/topic/78562-bfxr6-blown-engine-turbo-ford-extended-warranty-claim-refused/page/2/#findComment-1185116 Share on other sites More sharing options...
newguy11 New Member 24 Member For: 14y 2m 15d Gender: Male Location: Ossy Park Posted 27/01/12 04:31 PM Share Posted 27/01/12 04:31 PM within 3 months of purchasing it not mater the problems, regardless of what it is, its dealer that's responsible (unless it has been modded since or obviosuly treated sh*thouse-which I highly doubt it has) . did u get an extended warrenty with a company like awn?or similar. im from perth,bought a 2nd hand ba xr6t, turbo sh*t itself, diff sh*t itself.I treated it like a new baby. the trubo got dealer replaced (was within 3 months of buying car), diff got replaced on extended warrenty even before the 1st 10k service was due (was about 5 months after buying car).the warranty company was based in QLD. got serviced by a "qualified and registered" mechanic and all was sweet. Link to comment https://www.fordxr6turbo.com/forum/topic/78562-bfxr6-blown-engine-turbo-ford-extended-warranty-claim-refused/page/2/#findComment-1186856 Share on other sites More sharing options...
bilal Member 14 Member For: 15y 3m 15d Gender: Male Location: Melbourne Posted 29/01/12 07:57 AM Share Posted 29/01/12 07:57 AM My car was in extended warranty and I blew the engine from boosting it. I put the tune back to stock and took it to ford. They had no problems in fixing it. They ended up giving me a new engine. Sometimes it depends on who you talk to and which dealer you take it to. Link to comment https://www.fordxr6turbo.com/forum/topic/78562-bfxr6-blown-engine-turbo-ford-extended-warranty-claim-refused/page/2/#findComment-1187634 Share on other sites More sharing options...
