Does Bigger Intercooler = Retune Necessary
ZelchXR6T
  • Member For: 18y 5m 3d
Hi Guys,
My BF2 F6 is currently running standard intercooler and piping. The car has been flashed with the stock cooler/exhaust so I was wondering if I replace the standard intercooler with a bolt on larger core intercooler (stock piping) would I need a retune or will the computer learn it? From my limited knowledge I'd think not because its a variable that is regulalrly controlled by the outdoor temperature anyway. Just wanted to double check.
Also, what if I added a dump pipe and high flow cat to the equation?
I've been running considerably high power for some time now (at 323rwkw) with just larger injectors and want to cool things down and increase flow etc so that I don't lose out on hot days but don't have the bank balance to go all out thanks to upcoming replacement of some dead rear end bushes... :(
Your help would be appreciated! Cheers!
  • Member For: 16y 11m 3d
323 with just injectors :o. Who tuned it?
A dump and cat will definitely require a retune. Adding a Cooler. It no piping shouldnt, but I'm still baffled about this 320+kw.
  • Member For: 14y 7m 3d
  • Gender: Not Telling
The more effective the cooler the greater risk of inducing a lean condition, so I'm with MX Dave, don't go around boosting it up until you make sure you have safe air/fuel ratios, and not boost spiking which may cause a lean condition,as your tune my not have the approriate parameters/maps available, Cheers.
  • Member For: 17y 8m 28d
That much power with stock exhaust and intercooler doesn't sound right.. Definitely get it looked at.
