  • Member For: 14y 1m 17d
Hey all,
I have been driving turbocharged cars for a while now, with 2 having a fuel pressure gauge fitted.
Upon decel (throttle off) these always read 0psi as no fuel is being sent to the rail.
Lately I have noticed that my Inst. Econ. is reading 5-6L/100k on decel (throttle off) on my G6E turbo.
I was in N.Z recently and had an XR6 rental car and sure enough when I drove around in it, it had a 0.00L/100k Inst Econ.
Is there something wrong with my car? Fuel pressure regulator perhaps? I have noticed that it has been using a bit more petrol than usual. I'm using 95 E10.
Thanks for any replies,
CLuTZ
Edited by CLuTZ
https://www.fordxr6turbo.com/forum/topic/78524-inst-econ/
  • ʎǝʞuoɯ ɹoıuǝs
  • Member For: 16y 6m 17d
wouldn't it depend on what RPM you are getting off the throttle?
I will compare to the instant economy readout next time I drive, but according to my wideband it only cuts fuel if decelerating above 1.8 to 2k RPM (from memory)
Edited by JC807
https://www.fordxr6turbo.com/forum/topic/78524-inst-econ/#findComment-1180883
  • Will do skids for food
  • Member For: 13y 7m 29d
Mine shows both.
Sometmes it shows a number which increases as I slow down until it switches to Litres per hour when I'm stopped.
Other times it shows zero.
Dunno why it does different things.
Wierd.
https://www.fordxr6turbo.com/forum/topic/78524-inst-econ/#findComment-1180952
  • Member For: 19y 1m 6d
It shows zero when decel fuel shut off has been activated, it gets activated by a ceratin load value is acheived after a certain load value was being used before shutting throttle, it also requires a certain road speed before being activated and will return to normal fueling when a certain road speed has been met.
Edited by ratter
https://www.fordxr6turbo.com/forum/topic/78524-inst-econ/#findComment-1180995
Thanks for clearing that up- must be different for the N/A's because every time no matter what rev or speed, it would always decel on 0.
It got me thinking because I would have though it would've been the same if not close to the figure on idle.
Is this something that can be tuned to read as close to 0 as possible on any speed/load while decelerating?? It would reduce my fuel consumption dramatically!
Edited by CLuTZ
https://www.fordxr6turbo.com/forum/topic/78524-inst-econ/#findComment-1181052
