Paulie2256 Donating Members 7,441 Member For: 16y 6m 6d Gender: Male Location: SE Melbourne Posted 02/12/11 01:29 AM Share Posted 02/12/11 01:29 AM (edited) On 01/12/2011 at 10:26 AM, kartman said: Off our dyno the last GS auto I tuned made 235 rwkW stock and 335 rwkW when tuned, the GT on the other hand as an Auto made 295 rwkW stock and similarly 337 rwkW when tuned, the auto is more power hungry than the manual and the GS is possible lower in power than quoted, having said that when tuned the vehicles are the same in output, yay to Ford for making tune changes only.As for torque, unless the comparison is on the same dyno, in the same gear, with the same tyre size and diff ratio then there is really not much comparison to be made, the job of a gearbox and torque converter as well as differential gears is to multiply torque, a 1970 Corolla if dynoed in 1st gear ( if it wouldn't wheel spin) would make as much torque as a GS in 4th gear, I could put a 6 cylinder 4wd in low range and make more than the 2000 nM our dyno can hold if I wanted to. Gear ratios trade torque for speed, more speed in 4th than 3rd but less speed, power is the product of torque x speed so is more consistant, 3 x 2 = 2 x 3=6CheersI'm a bit confused by this. A TR6060 has a 4th gear ratio of 1.00:1. This means the torque figure would only be skewed by the diff. And of course a bit of loss from the clutch, gearbox, tailshaft, tyres etc.I apologise if I am missing something. Edited 02/12/11 01:30 AM by Paulie2256 Link to comment https://www.fordxr6turbo.com/forum/topic/78470-how-much-power-is-your-gs-making/page/3/#findComment-1165006 Share on other sites More sharing options...
Ewaaaah Member 38 Member For: 14y 4m 10d Gender: Male Posted 02/12/11 12:29 PM Share Posted 02/12/11 12:29 PM Hey Howsee, if you get some spare time uploading your dyno sheets would be awsome!!! kinda excited to see what my car will make from what your done !! cheers Link to comment https://www.fordxr6turbo.com/forum/topic/78470-how-much-power-is-your-gs-making/page/3/#findComment-1165232 Share on other sites More sharing options...
Howsee Donating Members 785 Member For: 17y 7m 22d Gender: Male Location: Carindale, Brisbane Posted 03/12/11 01:03 AM Share Posted 03/12/11 01:03 AM Here you go, red line is stock (304rwkw) and blue line is tuned (367rwkw), you can clearly see the torque difference between stock and tuned, it completely transforms the feel of the car.Hope this is a better indication of the torque difference :-)Howsee Link to comment https://www.fordxr6turbo.com/forum/topic/78470-how-much-power-is-your-gs-making/page/3/#findComment-1165347 Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 22y 1m 2d Gender: Male Location: Victoria Posted 03/12/11 01:25 AM Share Posted 03/12/11 01:25 AM On 02/12/2011 at 1:29 AM, Paulie2256 said: I'm a bit confused by this. A TR6060 has a 4th gear ratio of 1.00:1. This means the torque figure would only be skewed by the diff. And of course a bit of loss from the clutch, gearbox, tailshaft, tyres etc.I apologise if I am missing something.And the wheel diameter and dyno roller diameter. Link to comment https://www.fordxr6turbo.com/forum/topic/78470-how-much-power-is-your-gs-making/page/3/#findComment-1165360 Share on other sites More sharing options...
Ewaaaah Member 38 Member For: 14y 4m 10d Gender: Male Posted 03/12/11 05:53 AM Share Posted 03/12/11 05:53 AM On 03/12/2011 at 1:03 AM, Howsee said: Here you go, red line is stock (304rwkw) and blue line is tuned (367rwkw), you can clearly see the torque difference between stock and tuned, it completely transforms the feel of the car.Hope this is a better indication of the torque difference :-)HowseeThanks for putting this up mate!! im very impressed with your results and cant wait to show you guys my results aswell Link to comment https://www.fordxr6turbo.com/forum/topic/78470-how-much-power-is-your-gs-making/page/3/#findComment-1165464 Share on other sites More sharing options...
kartman Member 88 Member For: 15y 8m 17d Posted 03/12/11 11:44 PM Share Posted 03/12/11 11:44 PM (edited) On 02/12/2011 at 1:29 AM, Paulie2256 said: I'm a bit confused by this. A TR6060 has a 4th gear ratio of 1.00:1. This means the torque figure would only be skewed by the diff. And of course a bit of loss from the clutch, gearbox, tailshaft, tyres etc.I apologise if I am missing something.The difference in torque between the wheels and the engine is the ratio of roller rpm vs engine rpm, so tyre size, diff ratio, gear ratio and torque convereter all contribute, for example a 4th gear dyno on stock tyres with stock gears might be a round 0.5, the rollers are doing 2500 rpm when the engine is doing 5000 rpm, therefore the measured torque at the wheels is double the engine, the speed is half therefore the torque must be double. In theory you should be able to work out the ratio of absolute final gearing by comparing roller speed to engine rpm and then if the dyno measures torque accuratly the work out the approximate engine torque.Joel Edited 03/12/11 11:52 PM by kartman Link to comment https://www.fordxr6turbo.com/forum/topic/78470-how-much-power-is-your-gs-making/page/3/#findComment-1165662 Share on other sites More sharing options...
etrocket Member 1,382 Member For: 15y 1m 29d Gender: Male Posted 06/12/11 02:02 AM Share Posted 06/12/11 02:02 AM what are these cars doing 1/4 mile stock. best I've seen is high 12's which doesnt equal 300rkw Link to comment https://www.fordxr6turbo.com/forum/topic/78470-how-much-power-is-your-gs-making/page/3/#findComment-1166411 Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 6m 6d Gender: Male Location: SE Melbourne Posted 06/12/11 02:04 AM Share Posted 06/12/11 02:04 AM On 03/12/2011 at 11:44 PM, kartman said: The difference in torque between the wheels and the engine is the ratio of roller rpm vs engine rpm, so tyre size, diff ratio, gear ratio and torque convereter all contribute, for example a 4th gear dyno on stock tyres with stock gears might be a round 0.5, the rollers are doing 2500 rpm when the engine is doing 5000 rpm, therefore the measured torque at the wheels is double the engine, the speed is half therefore the torque must be double. In theory you should be able to work out the ratio of absolute final gearing by comparing roller speed to engine rpm and then if the dyno measures torque accuratly the work out the approximate engine torque.JoelSweet thanks. Link to comment https://www.fordxr6turbo.com/forum/topic/78470-how-much-power-is-your-gs-making/page/3/#findComment-1166412 Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 21y 1m 3d Gender: Male Location: Brisbane Posted 10/01/12 10:50 PM Share Posted 10/01/12 10:50 PM Bit of a Apologies if anything legitimate got removed, as there was that much crap in here I gave up going through each post. Keep it on-topic our you're on a holiday. End of story. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/78470-how-much-power-is-your-gs-making/page/3/#findComment-1179310 Share on other sites More sharing options...
Howsee Donating Members 785 Member For: 17y 7m 22d Gender: Male Location: Carindale, Brisbane Posted 10/01/12 10:52 PM Share Posted 10/01/12 10:52 PM On 06/12/2011 at 2:02 AM, etrocket said: what are these cars doing 1/4 mile stock. best I've seen is high 12's which doesnt equal 300rkwMine managed a 12.81 Link to comment https://www.fordxr6turbo.com/forum/topic/78470-how-much-power-is-your-gs-making/page/3/#findComment-1179313 Share on other sites More sharing options...
