  • Member For: 14y 8m 10d
If it was the timing chain wouldnt it do it cold as well as warm, cold the engine is super quiet only thing you can hear is the injectors
  • Replies 23
  • Member For: 14y 7m 4d
As I stated in the other forum, drop the belt off, and see if the noise goes away. That will eliminate the idler, and water pump.
Nah im not touching it,knowing my luck with this car recently it wont go back on and I will have to tow it to my tuner.Anyway tuners back monday so he can sort it out.
  • Member For: 14y 3m 26d
It's easy to get off. All you need is a 3/8" strong arm bar from your socket set to release the tension on the tensioner (no actual bolts to undo). I spent a while trying to put a new belt on once because I took no notice of how it came off and they are a long belt with lots of possible ways to go on.
  • Member For: 17y 1m 24d
  On 08/01/2012 at 7:38 AM, hawlass said:
Idler pulley and a belt while your in there would be a good start, although I think the pulley is more of a squeak from memory. Do a search, its been covered in here already.
This, idler pulley.
Just read last post. Winnerrrrrr
Edited by Henz
