superdogster Member 4 Member For: 18y 5m 26d Posted 08/01/12 12:34 AM Share Posted 08/01/12 12:34 AM Hey GuysI have an 09 fg ute on 20's with lowered king spring springs in the rear, I notice that when I turn corners or swerve down the road I got a knocking/clunking sound from what sounds like the drivers side rear wheel.I have had the car on stands twice and double checked all my nuts/ bolts, greased up linkage and still continues to do it.Ute only has 25,000 kms on itCould any please offer some assistance with this problem as it is driving me up the wall not being able to solve the problemThanks in advance Link to comment Share on other sites More sharing options...
johno Donating Members 773 Member For: 14y 3m 21d Gender: Male Location: Mt Gambier, SA Posted 08/01/12 12:43 AM Share Posted 08/01/12 12:43 AM Have you checked to see if your exhaust is hitting on anything? My BA has the same problem, and its the exhaust hitting the towbar mount.Fair bit of movement in the exhaust rubbers down the back.Also, have you greased between the leaves? Lowered springs can get noisy . Link to comment Share on other sites More sharing options...
timmy Massive Tool Donating Members 567 Member For: 16y 4m 19d Gender: Male Posted 08/01/12 02:34 AM Share Posted 08/01/12 02:34 AM no cost factory option me thinks. Mine has done it since new as well Link to comment Share on other sites More sharing options...
*XR Baby* Member 139 Member For: 15y 3m 7d Gender: Female Location: Adelaide, SA Posted 13/01/12 11:20 AM Share Posted 13/01/12 11:20 AM Utes clunk. All four of mine have done it including my fg Link to comment Share on other sites More sharing options...
cjsxrt Donating Members 145 Member For: 16y 1m 19d Posted 13/01/12 11:17 PM Share Posted 13/01/12 11:17 PM Mine done it in my ba then found out it was the bearing on the axel and also the axel not being tight ford told my dad as he is a mechanic that the axles can loosen off a little Link to comment Share on other sites More sharing options...
getuted Member 34 Member For: 15y 7m 23d Gender: Male Location: brisbane Posted 09/02/12 10:54 AM Share Posted 09/02/12 10:54 AM Not sure if this will help but I had the same noise coming from the same area in my ba mk 2 and it turned out to be the bolt those goes throught the front leaf spring eye was loose. Locktite 271 and a new lock nut fixed the issue. Also try checking your spare wheel is pulled up hard on the tray stops. Link to comment Share on other sites More sharing options...
baxr6ute Member 77 Member For: 17y 4m 13d Gender: Male Location: Townsville Posted 10/02/12 02:23 AM Share Posted 10/02/12 02:23 AM As silly as it sounds try changing your diff oil.As I posted the thread about noisy diff. Mine use clung aswell... Link to comment Share on other sites More sharing options...
emjay992 Inactive Members 1 Member For: 12y 7m 11d Posted 21/06/12 02:36 PM Share Posted 21/06/12 02:36 PM any instructions on fitting towbar kit to fgR6 diy, new to forum any suggestions much appreciated. Link to comment Share on other sites More sharing options...
