GoodVibe Member 30 Member For: 15y 1m 5d Gender: Male Location: Campbelltown Posted 05/01/12 09:53 AM Share Posted 05/01/12 09:53 AM Im in need of help from the collective knowledge of the forum.In about the last 2 weeks my car has developed a problem on boost, when on the throttle my boost gauge will move from -20 vac to +1 boost as it always has but will stop on 1 for a few seconds then jump straight to 5/6psi, the car doesn't seem to have the pull it used to so I think I believe the gaugeI have tried to clean the boost solenoid and have checked all hoses for leaks but I can't find anything that affects it.Car is stock except for f6 intake, f6 cooler and a bovAnyone have any ideas cause I'm stumped, my only thought is my knock off dual port bov might not be holding boost Link to comment https://www.fordxr6turbo.com/forum/topic/78416-weird-boost-issue/ Share on other sites More sharing options...
TXR05 Member 181 Member For: 13y 10m 17d Gender: Male Location: Brisbane QLD Posted 10/01/12 07:53 AM Share Posted 10/01/12 07:53 AM Sounds like the gauge is stuffed and you're getting a placebo effect. Link to comment https://www.fordxr6turbo.com/forum/topic/78416-weird-boost-issue/#findComment-1179090 Share on other sites More sharing options...
