Ninka Donating Members 1,850 Member For: 21y 9m 4d Gender: Male Location: Perth, WA Posted 03/01/12 10:10 AM Share Posted 03/01/12 10:10 AM Well, you missed the milky oil bit in your first post, quite a critical bit on information.....There are only really a few places where water can enter the oil, and first suspects would be head gasket, warped head, or if you run a Ford oil cooler, maybe it has split and allowed water into the oil.Most likely you have had water enter from the head, and there is a good chance that you have lost compression on cylinder 1, either due to compression leak through head gasket (best case) or a broken ring land due to some kind of over pressure, possibly due to water in the cylinder.The turbo blowing is hardly a surprise if you have had a lot of water in the oil, as it will turn to steam in the bearing housing, displacing any oil in there, and probably 'gas locking' due to rapid expansion of steam, overcoming the oil pressure. My 2c worth Link to comment Share on other sites More sharing options...
JVK Silver Donating Members 751 Member For: 18y 9m 9d Gender: Male Location: North West Hot Hell,VIC Posted 03/01/12 07:20 PM Share Posted 03/01/12 07:20 PM Between Ratter and Ninka there isnt much more left. You might just have to recheck a little better. Link to comment Share on other sites More sharing options...
Power Jet Member 151 Member For: 16y 4m 15d Gender: Male Posted 04/01/12 06:51 AM Author Share Posted 04/01/12 06:51 AM haha. I shouldn't laugh guys but found the problem today. Nice crack in cylinder 1. New block and start again. Could a crack in the cylinder bore cause the water to go into the oil :( Link to comment Share on other sites More sharing options...
Pazzo Donating Members 11,132 Member For: 13y 11m 5d Gender: Male Posted 04/01/12 07:06 AM Share Posted 04/01/12 07:06 AM Built motor maybe now? Link to comment Share on other sites More sharing options...
JVK Silver Donating Members 751 Member For: 18y 9m 9d Gender: Male Location: North West Hot Hell,VIC Posted 04/01/12 09:33 AM Share Posted 04/01/12 09:33 AM haha. I shouldn't laugh guys but found the problem today. Nice crack in cylinder 1. New block and start again. Could a crack in the cylinder bore cause the water to go into the oil :(Ummmm ................Yes. Link to comment Share on other sites More sharing options...
Power Jet Member 151 Member For: 16y 4m 15d Gender: Male Posted 05/01/12 09:04 AM Author Share Posted 05/01/12 09:04 AM guys that's the depressing part :(I already built the motor in Feb just gone. Mahle pistons, atomic rods, port and polished head, oil gears. So instead of changing oil every 5000km, I do it differently and change a ENGINE EVERY 5000KM. *cries*. Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 4m Gender: Male Location: @ my laptop Posted 05/01/12 09:08 AM Share Posted 05/01/12 09:08 AM Was the bore thickness tested when the rebuild was done? Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 3m 27d Gender: Male Location: Adelaide Posted 05/01/12 09:26 AM Share Posted 05/01/12 09:26 AM a decent engine builder would take the time to do a sonic test on the bore walls to find min thickness , lots of ppl just wack new bits in a old oblong block or never pay to have the bores at least honed to start from somewhat clean slateonly time this is half excepted is when the owner has a go at building a donk with little knowledge, but enough to get it back together againsorry for your loss Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 4m Gender: Male Location: @ my laptop Posted 05/01/12 09:52 AM Share Posted 05/01/12 09:52 AM (edited) a decent engine builder would take the time to do a sonic test on the bore walls to find min thickness , lots of ppl just wack new bits in a old oblong block or never pay to have the bores at least honed to start from somewhat clean slateonly time this is half excepted is when the owner has a go at building a donk with little knowledge, but enough to get it back together againWhich is what I was trying to point out in Dillz thread re engine builders, there is so much more to an engine build to just putting new pistons in the holes Edited 05/01/12 09:52 AM by ratter Link to comment Share on other sites More sharing options...
Ninka Donating Members 1,850 Member For: 21y 9m 4d Gender: Male Location: Perth, WA Posted 05/01/12 11:47 AM Share Posted 05/01/12 11:47 AM Which is what I was trying to point out in Dillz thread re engine builders, there is so much more to an engine build to just putting new pistons in the holesHaving done this a few times - Hear, hearThe list of things to check is looong, and you have to be ready to scrap items which are not up to scratch, for whatever reason.From memory, I think Atomic only use about 60% of blocks they look at, as others suffer from one problem or another, and wall thickness inconsistencies is one of them. Link to comment Share on other sites More sharing options...
