  • Member For: 16y
yes this is yet another question about engine noise....have been searching for a problem similar to mine but that's all I have really found - similar problems
I am getting a ticking noise (sounds like a plastic tab flicking on a bike wheel - yes old school style) coming from the engine region....
It only happens when:
engine is warm (not cold)
It starts at 1psi and the sound becomes faster as it goes up to 10psi (which my current tune is on)
I took my process west race intake off and made sure nothing was touching turbine etc all seem fine. I possibly thought it could be a bit of movement in the turbo shaft and turbine.
Current mods to car:
exhaust
intake + intercooler + plenum
injectors
12psi actuator
actuator mod
fuel pump
tune
https://www.fordxr6turbo.com/forum/topic/78363-yet-another-engine-noise/
  • Member For: 16y
Yeah turbo definately getting oil - replaced feed line with an earls inline filter. Checked to see if oil making it all the way through and it is.
Lifter? What is a that? sorry noob question
Wouldnt an exhaust leak be heard all the time??
Ill see if I can try make a video recording of it
  • Member For: 16y
Ahh sorry forgot to mention most important peice of information - thing to remember is yes it does only happen when engine is warm BUT its not every single time the engine is warm. Its a random draw whether it makes the noise or not. But when it does make the noise it wont stop until engine is cold.
I think that would cross exhaust leak out
Ill check the bolts but unless one is loss I wouldnt think it would be that??
Unplug boost solinoid? is that safe to drive with it off? lol
  • I <3 Floods
  • Silver Donating Members
  • Member For: 13y 8m 29d
When you say it makes the noise until the engine is cold.. Do you mean even if the car is switched off? If so how long does it run while it's switched off? I'm thinking cooling fan.. or Expansion/Contraction of something metal.. If you've got a stainless exhaust they expand alot when heated so maybe it's fouling on something?
Edited by Porno Panda
