wa g6et Member 657 Member For: 13y 11m 29d Gender: Male Location: Perth NOR Posted 12/01/12 09:58 PM Share Posted 12/01/12 09:58 PM (edited) Used mine yesterday(37deg here in Perth), set to 20deg on Auto within minutes too cold, set to 22deg even still very cold. Outside temp showing 35deg, my car has good quality tint and is white, guess this helps too.Maybe semi-auto warmer air to feet is just the way the mixing takes place as the climate control regulates the temp in the cabin.The air from my vents freezes my hands if the air is pointed directly at me.Obviously there are differences between built dates with the aircon on the FGs. Seems it possible they sorted it on the euro4 2010 update builds. Read somewhere the refridgerant quanity is now higher in the later builds, bigger compressor? Edited 12/01/12 10:05 PM by wa g6et Link to comment https://www.fordxr6turbo.com/forum/topic/78350-g6et-faults-to-look-for-b4-purchasing/page/4/#findComment-1180120 Share on other sites More sharing options...
Never had any say Panda I <3 Floods Silver Donating Members 11,198 Member For: 13y 10m 1d Gender: Male Location: South West QLD Posted 12/01/12 10:12 PM Share Posted 12/01/12 10:12 PM 08 FG.. Aircon was freezing (Set on 25 celsius) as described above.. After it went back to ford and got reflashed and something else electrical done to it.. First thing I noticed was that the aircon wasn't as cold as it was.. So to get about the same feel in the cabin I had previously I now have to set it on 20.. Link to comment https://www.fordxr6turbo.com/forum/topic/78350-g6et-faults-to-look-for-b4-purchasing/page/4/#findComment-1180124 Share on other sites More sharing options...
tuono Member 312 Member For: 14y 6m 19d Posted 13/01/12 06:02 AM Share Posted 13/01/12 06:02 AM Ive never had freezing air in any mode. Good to hear its possible, especially at 37!! Im going to fire up next service. Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/78350-g6et-faults-to-look-for-b4-purchasing/page/4/#findComment-1180293 Share on other sites More sharing options...
JETG6E Member 9 Member For: 13y 6m 29d Posted 17/01/12 02:15 AM Share Posted 17/01/12 02:15 AM Went to use me horn the other day at some lunatic and it didnt work took it back to ford and they told me it wasn't even connected Link to comment https://www.fordxr6turbo.com/forum/topic/78350-g6et-faults-to-look-for-b4-purchasing/page/4/#findComment-1181891 Share on other sites More sharing options...
Rubberman Member 37 Member For: 14y 6m 22d Gender: Male Posted 20/01/12 03:39 AM Author Share Posted 20/01/12 03:39 AM On 17/01/2012 at 2:15 AM, JETG6E said: Went to use me horn the other day at some lunatic and it didnt work took it back to ford and they told me it wasn't even connectedso hows your voice now ? Link to comment https://www.fordxr6turbo.com/forum/topic/78350-g6et-faults-to-look-for-b4-purchasing/page/4/#findComment-1183646 Share on other sites More sharing options...
tuono Member 312 Member For: 14y 6m 19d Posted 20/01/12 03:43 AM Share Posted 20/01/12 03:43 AM I want to know how his horn is, sounds painful. Link to comment https://www.fordxr6turbo.com/forum/topic/78350-g6et-faults-to-look-for-b4-purchasing/page/4/#findComment-1183649 Share on other sites More sharing options...
FG XR6-T MONSTER Member 42 Member For: 16y 1m 12d Gender: Male Location: Adelaide Posted 22/01/12 01:07 PM Share Posted 22/01/12 01:07 PM Yea I get the same on mine XR6-T, but I don't worry about since I almost never switch the aircon on. Link to comment https://www.fordxr6turbo.com/forum/topic/78350-g6et-faults-to-look-for-b4-purchasing/page/4/#findComment-1184650 Share on other sites More sharing options...
hrick Member 210 Member For: 15y 5m 17d Posted 22/01/12 07:57 PM Share Posted 22/01/12 07:57 PM On 10/01/2012 at 3:05 AM, wa g6et said: With my climate set on semi auto 22deg (around 30deg outside and with either vented or recirc) I get noticeable warmer air to my feet compared to the dash vents. It's not until I drop the temp to 19deg that this air gets close to the same temp as the dash vents. I realise there is air mixing occurring at some point but do others have this happening.Yep, mine does the exact same thing, not sure if its a mixer thing happening, maybe if I left it on long enough the feet temp would change? but I always alter (decrease)the temp before that (so it cools ma feet. Link to comment https://www.fordxr6turbo.com/forum/topic/78350-g6et-faults-to-look-for-b4-purchasing/page/4/#findComment-1184670 Share on other sites More sharing options...
KeepLeft Member 240 Member For: 15y 11m Gender: Male Posted 23/01/12 01:20 AM Share Posted 23/01/12 01:20 AM (edited) Here's my list of problems fixed under warranty:Climate control in passenger side footwell broken twice. Only cold air blowing from that vent.Ambient air temperature sensor 10-15 degrees off. Made climate control blow too hot all the time.Diff bushes after 20000km. Lived with it for a while, then fixed under warranty, then broken again like 2000km later.Driver's door hinge broken.Glovebox opening no longer smooth. Got stuck once and I broke the clip trying to open it.Front discs warped creating brake shudder at 100km/h+.Water dripping from driver's side footwell aircon vent.Driver's window kept winding down even though it was all the way down until the motor burnt out. Edited 23/01/12 01:24 AM by KeepLeft Link to comment https://www.fordxr6turbo.com/forum/topic/78350-g6et-faults-to-look-for-b4-purchasing/page/4/#findComment-1184726 Share on other sites More sharing options...
tuono Member 312 Member For: 14y 6m 19d Posted 23/01/12 02:13 AM Share Posted 23/01/12 02:13 AM On 23/01/2012 at 1:20 AM, KeepLeft said: Here's my list of problems fixed under warranty: Climate control in passenger side footwell broken twice. Only cold air blowing from that vent.Ambient air temperature sensor 10-15 degrees off. Made climate control blow too hot all the time.Diff bushes after 20000km. Lived with it for a while, then fixed under warranty, then broken again like 2000km later.Driver's door hinge broken.Glovebox opening no longer smooth. Got stuck once and I broke the clip trying to open it.Front discs warped creating brake shudder at 100km/h+.Water dripping from driver's side footwell aircon vent.Driver's window kept winding down even though it was all the way down until the motor burnt out.Ouch!! that's annoying, built on a Friday? Link to comment https://www.fordxr6turbo.com/forum/topic/78350-g6et-faults-to-look-for-b4-purchasing/page/4/#findComment-1184732 Share on other sites More sharing options...
