camo86T Silver Donating Members 1,810 Member For: 11y 1m 25d Gender: Male Location: SW Sydney Posted 29/01/20 10:36 AM Share Posted 29/01/20 10:36 AM Manual says M10 @ 60Nm but no length specified. My trans is out so I'll check bolts in the morning if I remember Link to comment Share on other sites More sharing options...
camo86T Silver Donating Members 1,810 Member For: 11y 1m 25d Gender: Male Location: SW Sydney Posted 30/01/20 06:37 AM Share Posted 30/01/20 06:37 AM @aussie1jzs13 bit late sorry M10 x 1.0 pitch, 20mm long, nothing special just 8.8s That's what was in mine anyway, may not be stock Link to comment Share on other sites More sharing options...
aussie1jzs13 New Member 9 Member For: 13y 5m 29d Posted 11/02/20 05:49 AM Share Posted 11/02/20 05:49 AM Thanks for the feedback have not pulled mine yet. Might be tomorrows job 🤗 Link to comment Share on other sites More sharing options...
Slowxr6t Member 569 Member For: 6y 4m 3d Location: New zealand Posted 11/10/21 05:23 AM Share Posted 11/10/21 05:23 AM So I'm about to attempt to take zf out of my fgx with assistance of a fairly capable mate, iv got starter motor off, was a bit of a pain, but got there in end. How do you get to torque converter bolts? I can't see a removable cover on the zf to get to tc bolts. Also to get the driveshaft off first, do I undo the bolts that hold the big round rubber shock absorber onto the zf flange so the rubber thing comes with the driveshaft? And drop the middle driveshaft cross member? The diff end of ds looks like the yolk is sitting in a recess and won't just drop down. Will I need to take the rubber damper on zf end completely off to be able to get ds out of diff end? Thanks guys. Link to comment Share on other sites More sharing options...
Slowxr6t Member 569 Member For: 6y 4m 3d Location: New zealand Posted 11/10/21 07:52 AM Share Posted 11/10/21 07:52 AM @Puffwagoncan you help me with my removing zf post and also do you have to drain trans oil before getting box out and once you've got all bell housing bolts out and have started to move trans back do you keep levering torque converter into trans until it's off crank? Link to comment Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,247 Member For: 10y 2m 8d Gender: Male Location: South Australia Posted 11/10/21 08:35 AM Share Posted 11/10/21 08:35 AM There is a plastic bit in the sump that comes out to reveal the torque converter bolts. I'll get a pic after if needed. You don't have to drain the oil to pull the box. The torque converter will stay with the box once it's undone. It could fall out with a hectic angle but very unlikely to with normal removal. The box will come straight down after you get it off the dowels. Link to comment Share on other sites More sharing options...
Slowxr6t Member 569 Member For: 6y 4m 3d Location: New zealand Posted 11/10/21 08:47 AM Share Posted 11/10/21 08:47 AM @Puffwagoncan you help me with my removing zf post and also do you have to drain trans oil before getting box out and once you've got all bell housing bolts out and have started to move trans back do you keep levering torque converter into trans until it's off crank? Awesome thanks puff Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 10m 6d Gender: Male Location: Adelaide Posted 11/10/21 11:23 AM Share Posted 11/10/21 11:23 AM FG/X ZF’s require Torque converter bolts to be removed from the Starter motor hole … no bell housing inspection cover on dem ones 1 Link to comment Share on other sites More sharing options...
Slowxr6t Member 569 Member For: 6y 4m 3d Location: New zealand Posted 11/10/21 07:11 PM Share Posted 11/10/21 07:11 PM Ok thanks @JETURBOdoes that make it difficult, any pro tips for getting tc bolts out? Link to comment Share on other sites More sharing options...
Rob70 Silver Donating Members 82 Member For: 4y 11m 28d Gender: Male Location: Wellington, NZ Posted 11/10/21 08:05 PM Share Posted 11/10/21 08:05 PM It's a big fiddly Richard but not difficult by any means, just spin engine over and line each one up like normal, you'll probably have to operate more on feel than sight, it's a bit tight up in there, just don't go dropping any bolts when yr re installing them, there's a pro tip right there... 😅 Link to comment Share on other sites More sharing options...
